P3A Not enough force/ESC Error
Italy
Hello,
my P3A lost altitude when I activate "go home".
I see logs on airdata: all was ok (GPS, sensors, ...)
I was flying in P-mode, when I switch to "return home" using button on remote control
On logs, just after flight mode change from p-mode to go home, I can see severals:
Not Enough Force/ESC Error
and after i can see:
Motor is Blocked. Not Enough Force/ESC Error
It was loosing 2-3m/s vertically and after a while it touch a tree, crashing with little damages.
I checked also old logs on airdata, I can't find ESC o motors error on old logs. In old logs there "auto return home" was not activated.
Now I rapaired it (changing only plastic parts), and make only one little flight to test. It seems all ok.
Do you have any idea about this issue?
Could be a debris on motor?
It is reated to "auto return home"?
Thank you
I had received several errors similar to yours on my P4 Pro plus and it turned out that the battery was going bad it was swollen and had to be replaced.
akos9703
