both are reporting success...Did you get a txt file message on the sd card after the firmware update on the P3 stating "Success" after the update ? and also from the controller showing "success" ? it will be on the sd card with the bin file.
all i get is a slight jiggle of the camera gimbal... APP shows disconnectedturn it all on, pull the RC sticks down and to the center, to start motors, right stick down and left, left stick down and right, all the way down
1.2.6while connected to Phantom, in the APP, look for the "about" tab and click to see firmware version
1.2.6
calibrated aircraft by moving a/c in a slow 360 turn to right, set it back on floor, another slow 360 turn to right with a/c held vertically... anything else i need to do?you did upgrade, you must calibrate IMU, gimbal and RC
went to RC calibrate in app.. i get warning flag to center all joysticks.. which i did.. press START and all the app does is repeat the centering warning...calibrated aircraft by moving a/c in a slow 360 turn to right, set it back on floor, another slow 360 turn to right with a/c held vertically... anything else i need to do?
got it.. will give it a try.. thanks so much for your help and patience!NO, in the APP. under sensors, do IMU calibration (on a level surface), under camera, do gimbal calibration, under RC do RC calibration, read the manual....... go ahead and start motors for a few seconds to see if it works
i don't think RC controller is talking to A/C... it shows disconnected and i get no response to calibration commands thru the app..
yes, it is plugged into iPad mini... will watch videos againdid you plug tablet into the usb port on bottom of RC, you using phone or tablet and what type?
You need to read the manual thoroughly watch some you tube vids, they are helpful
Did you set up your account yet? This is part of binding to your device.
