P1 fast flashing reds.
London, UK
It's been some while since I looked in here. But I dug out my old P1. Everything fired up OK- and it flew as good as the day I bought it.
I had a full set of greens and 'home lock' had confirmed. Then [in flight] I got fast reds for a moment or two. The craft flew normally though and the LEDs went back to greens.
Then the fast reds came back- so I landed.
Before flying I had done the dance routine- all LEDs reported correctly. Back home I hooked up to the Assistant- but all looked OK.
What have I forgotten?
i dont kmow what the flash codes for the P1 are but typically they mean critical battery voltage and will occasionally pop up under high current draw, particularly on a partially discharged older battery.
Reactions: discv
That’s exactly what it is, first stage low voltage alert. Old lipos can drop to critical from fully charged quickly. If you putt around they might run for a bit. Those lipos are not expensive if you can source the correct size.
Reactions: discv
Thanks guys- guess I'm going to bite the bullet and buy a new battery, given that the present one is some 7 years old! Though I might be able to squeeze a few flights- the assistant is showing current voltage of 12.3 and the 1st level protection is set at 11.2.
I don't understand this.... I had a full set of greens and 'home lock' had confirmed. Then [in flight] I got fast reds for a moment or two. The craft flew normally though and the LEDs went back to greens. ,,,There is only one status led on phanton
Monte55- another name I remember from the early P1 days!
Yes- I'm talking about the single status led- that changed from slow greens, to fast reds, and back to slow greens.
And then I took no chances and landed ASAP.
If this help
Reactions: discv
muskansahu
