A bit disappointed only getting it up to 200m and then it comes back down. Using a sumsung 3 lite it says
it out of range,hope its not the P3S. Is it the app or should l use a ipad instead.
No way to say with no information.
Neither the tablet or the app have any influence on range.
Antenna orientation is the most important factor.
How's your antenna aimed?
If you're going straight up like your post suggests ..... AHHHH what happened!?!?!? | DJI Phantom Forum
It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
You should be getting about a kilometer in the stock form. Are you flying in an urban area with lots of radio 'noise'? What position do you have your TX antenna?
And yes l was in away going straight up and at one stage l was about 100m in front of me[ still about 200m up in the air] and it still wanted to return home.
