6 months warranty on the camera/gimbal.
Could this have have happened from being in a hot car?
Highly doubtful. There are commercial grade electrical components all over the place inside your car. I suspect one of the processors on the gimbal main board is failing due to exceeding operating temp. Inside the assembly, there are 2 chips, one TI, one Amberella (video processor), that have thermal pads glued to the case that are supposed to transfer heat away from the chips.There is also a tiny fan. I'm not sure if that is where the failure is occurring, but it seems likely given the effort the designer(s) put in to try to dissipate heat for these components in particular. I don't think it would be a simple resistor, if these fail, they typically burn open, and I see no evidence of this on my test sample.Could this have have happened from being in a hot car?
This is what I just now sent to DJI support:
Today, June 24th, I boot up my P3P and there is no video signal with the error: "No Image Transmission Signal" and the video signal would turn on then turn off and was very choppy looking with lots of video artifacts in the signal.
When I searched the DJI Phantom 3 forums for "No Image Transmission Signal", it appears a lot of people are having this same problem after they had updated to the new firmware release P3X_FW_V01.09.0060
But they also found a solution to the problem: they took the MicroSD memory card out of the Phantom's camera drive and the video image transmission became stable.
I have several MicroSD cards:
Lexar 633x 16GB UHS speed class 1 in a "U" and class 10 in a "circle" - 10MB/s transfer speed (this is the MicroSD card that came with my P3P)
SanDisk Ultra Plus 16GB UHS speed class 1 in a "U" - 10MB/s transfer speed (this MicroSD card was designed specifically for 1080p video)
SanDisk Extreme Pro 32GB UHS class 3 in a "U" - 30MB/s transfer speed (this MicroSD card was designed specifically for 4K video)
Before I installed the P3X_FW_V01.09.0060 firmware update, my SanDisk Extreme Pro 32GB UHS class 3 in a "U" MicroSD card worked fine and the video transmission signal was perfect.
AFTER I installed the P3X_FW_V01.09.0060, all I get is "No Image Transmission Signal" error.
But when I use the SanDisk Ultra Plus 16GB UHS speed class 1 in a "U" MicroSD card in the P3P, for now, I get no video transmission signal errors.
Flying my P3P without a memory card is not an option.
DJI, you need to fix your update so that we can use memory cards up to the promised 64GB and be able to use MicroSD cards designed to record 4K video.
So yes, if I remove the MicroSD card, the video signal missing problem goes away.
If I use the substandard SanDisk Ultra Plus 16GB UHS speed class 1 in a "U" I get a stable video signal but this card was not designed to record 4K video smoothly.
This problem needs to be fixed ASAP.
By the way, this link was helpful in my writing this to DJI:
Secure Digital - Wikipedia, the free encyclopedia
Multicoptertec - thanks for the reply. I actually have three problems:My photos do not save to my iPad, I have to connect the bird, and download them.
Sent from my QMV7B using PhantomPilots mobile app
That's a relief. Regarding the processor, I don't want to go there since this P3P has only seen a few flights. Having only used CD and CF cards in cameras, I have little experience in UAS use.Nothing should corrupt the card, short of taking the battery out mid write. The micro SD connector is on the main gimbal board, which also contains the Amberella graphics processor chip. If the processor is flakey, this could all be related.
Absolutely correct, I am seeing the same thing on 3 different P3 Pro models now. DJI will not sell the board, or repair the camera/gimbal assembly alone, they tell me to send in the whole aircraft. Some parts they sell, some the don't, and that is disappointing.you guys getting this error "No Signal" is that you either
A: flew in very warm/hot environment and flew one time to many and burned the gimbal board or
B: did an upgrade without cooling down the bird with external fan blowing on it while it was upgrading.
In either case the main board gimbal has a component in it when it overheats it's done.
seen it million times and it's the same thing every time.
let me guess, everyone having this issues on P3P right?![]()
The motors can be started! And, I will update the FW then let you know if there are module failures. Thanks for hanging in there with me.Being that you have data from the Phantom telling you to the the home point has been set, I would think you could also start up the motors. If you can, you have duplex communications. Again, this "No image transmission" error seems to be exactly what the problem is, and outside of a bad cable, it points to the gimbal main board as the culprit. Easy proof of this is swapping the camera with another. Easy to do if you have another to test. Did you try to update firmware again to see if the log file shows a failure of modules 8 & 15?
Kyrvas, I have no idea why certain MicroSD cards cause this problem and others don't. My being stuck with using only the 16GB MicroSD card is ridiculous. I received two replies from DJI Tech support regarding this problem, the first response from them offered suggestions that I had already tried via DJI's Online Chat Tech Support... none of their suggestions worked. Then I replied to them that I had tried all their suggested "fixes" and re-told them how swapping out the MicroSD card "fixed" the No Image Transmission problem... their response was in essence "sorry, we will refer this to our engineers" and basically a hearty "good luck" was all the support I got. There is a new firmware update 2.8.4 to add Geofencing (which I thought the DJI GO app already had... sigh) and 360 Pano capability and "bug fixes" of which they didn't bother to tell us what these "bug fixes" fixed. Then I hear there's yet another firmware update coming the week of July 11th (rumor really, not confirmed) so I don't know if the MicroSD card / No Image Transmission issue will be fixed so we can use larger capacity MicroSD cards. Frankly, I don't know if I'm going to update again out of fear that if I do, something else will go sideways with my P3P.Thanks Bert for the thorough list of SD cards used. I have a similar problem with my P3P but it is not with FW update V01.09.0060.
My versions: GO App v2.8.3, P3P v1.08.0080, RC v1.6.0.
The original Panasonic 16 GB UHS I, speed class 3 in a U; also a C10 class works fine.
However, I bought a Sandisk Extreme Pro 32 GB UHS l, class 3 in U; it seemed to work for one flight but on checking the Editor, there was only one video saved on my iPad; no other stills nor video I took showed up. Also, the card could not be formatted in the GO App, plus my Mac computer cannot read it.
Could the GO App or firmware have corrupted the card?
I would like to use a 32 GB capacity card like the Extreme Pro to shoot 4K video but I don't want to buy another card and have that be corrupted.
Why are the original 16 GB cards not experiencing the "No image transmission signal" error? Surely there must be other pilots using large capacity SD cards without problems.
In my case, my P3P has been in 74F temp inside my house, when I updated the firmware, I didn't it inside my house at 74F temp. Before I updated the firmware, video image transmission was perfect using my 32GB MicroSD card, after the firmware update No Image Transmission error came up. Remove the 32GB MicroSD card, it transmits video image just fine, install a lesser 16GB MicroSD card and it transmits video signal just fine. Re-install my 32GB MicroSD card, No Image Transmission error occurs once again. So clearly, temperature was not an issue as all this testing was done inside, at 74F degrees, the P3P was never outside in any heat and it was not sitting around inside my house, turned-on, heated up. So I'm going to bet it was the firmware update, not heat, that is the cause.you guys getting this error "No Signal" is that you either
Hi Bert - As noted above, post 23,Kyrvas, I have no idea why certain MicroSD cards cause this problem and others don't. My being stuck with using only the 16GB MicroSD card is ridiculous. I received two replies from DJI Tech support regarding this problem, the first response from them offered suggestions that I had already tried via DJI's Online Chat Tech Support... none of their suggestions worked. Then I replied to them that I had tried all their suggested "fixes" and re-told them how swapping out the MicroSD card "fixed" the No Image Transmission problem... their response was in essence "sorry, we will refer this to our engineers" and basically a hearty "good luck" was all the support I got. There is a new firmware update 2.8.4 to add Geofencing (which I thought the DJI GO app already had... sigh) and 360 Pano capability and "bug fixes" of which they didn't bother to tell us what these "bug fixes" fixed. Then I hear there's yet another firmware update coming the week of July 11th (rumor really, not confirmed) so I don't know if the MicroSD card / No Image Transmission issue will be fixed so we can use larger capacity MicroSD cards. Frankly, I don't know if I'm going to update again out of fear that if I do, something else will go sideways with my P3P.
Kyrvas, I have P3P 1.9.60 GO app 2.8.4 RC 1.6.0. I tried your format of my 32GB SD card with my iMac then reformat it with the GO app, I still get the NITS error, but then my previously functioning 16GB SD card caused the NITS error! After a few reboots of the RC and the P3P, the 16 GB SD card works again... meaning I get stable Image Transmission again, so your method did not work for me. Yes, my RC was set up to auto update so mine is at 2.8.4Hi Bert - As noted above, post 23,
My versions: GO App v2.8.3, P3P v1.08.0080, RC v1.6.0. Like you, my problem relates to a 32 GB card. Recently, I was able to erase the card with Disk Utility on my Mac. Then I put it into the P3P and the GO app suggested that I format it (which I was planning to do after the erasing); the formatting was super quick.
Currently the NO IMAGE TRANSMISSION SIGNAL (NITS) is not displaying; I get Safe to Fly in P-GPS.
Next, probably tomorrow, I will transfer the current aircraft firmware v1.08.0080 to the 32 GB card then fly it. If the flight goes well, I will probably not update the firmware. If the NITS returns, I will consider updating the firmware to 1.9.60 to take Multicoptertec's advice and view the log file for module failures.
Bert - clearly I don't understand what is going on; why would rebooting several times produce recognition of the 16 GB card with no error msgs? What if you took the 32 GB card and Erased it in Disk Utility then Format it in your P3P?Kyrvas, I have P3P 1.9.60 GO app 2.8.4 RC 1.6.0. I tried your format of my 32GB SD card with my iMac then reformat it with the GO app, I still get the NITS error, but then my previously functioning 16GB SD card caused the NITS error! After a few reboots of the RC and the P3P, the 16 GB SD card works again... meaning I get stable Image Transmission again, so your method did not work for me. Yes, my RC was set up to auto update so mine is at 2.8.4
Kyrvas, does it make sense that the type of MicroSD card put into the P3P's memory card drive would determine whether or not you get good or bad image transmission? No, it doesn't, none of this makes sense. The only difference between the method you used successfully (to solve this problem) was that your DJI GO app is one iteration older than mine (hence my mentioning that my DJI GO app auto-updated to 2.8.4) and your P3P firmware update is older than mine (my P3P is at 1.9.60) but my RC is at 1.6.0Bert - clearly I don't understand what is going on; why would rebooting several times produce recognition of the 16 GB card with no error msgs? What if you took the 32 GB card and Erased it in Disk Utility then Format it in your P3P?
The NITS goes away when there is NO MicroSD card in the gimbal's SD card drive.Anything is possible, but I have a hard time relating the size of the SD card to the NITS error. What about with NO SD card installed, do either of you still get the error? My theory is that the Ambarella chip on the gimbal board is possibly overheating, causing random shutdown. There is a whimpy sill pad on the cover that is designed as a thermal transfer solution. This pad is pressed against the chip when the cover is installed. This and the little fan are supposed to keep the chip within operating temp. A possible test for the SD card theory is to try both when the bird is dead cold, before the chip has a chance to go into thermal overload. Note that there are actually two chips that have two thermal transfer pads, I suppose either one could be failing, partially when overheated, or permanently destroyed.
