what can you say about the file phantom_hack.rar which rcdesign, maybe he's not quite right?
I have a second card there, there is no burning LED
Board after firmware uprgade or crash?
Thank you so much Sunset! I've already got an FTDI in my collection from my P1 days. Your manual and images are super helpful. I can't wait to try this!Manual, soft and dumps
ph3pns.zip
You run from c:? Without folders. And may be you nand broken after crashHave to mention normal SD card updates are failing on both boards, and flashing with this usb to serial adapter, I have tried both methods with p3p board connected to the bird, and second power connected thru USB serial adapter with 3.3v and 5v and same results as in the first picture. Appreciate any help, thanks.
Thank you for your manual, its all working now, yes I had to extract files directly to C: without folders only this worked took me 3 days to figure it out I guessYou run from c:? Without folders. And may be you nand broken after crash
Hi, yes I think you got all wiring connections right, you also can connect only RX and TX from P3P board with FT232RL board, and connect P3P board directly to drone and power drone on(just disconnect flex ribbon cable), I found both methods working for me.Hi Drons, just trying to follow your wiring, have I got this right?
1. Boot0 and Boot1 shorted out with lead going to 3.3V on P3P board.
2. Lead from 3.3V on USB to TTL FT232RL board to 3.3V on P3P board.
3. Lead from 5V on USB to TTL FT232RL board to 5V on P3P board.
I think I'm ok with the other connections but I will add my understanding to check if I've got it right.!
4. Lead from GND on USB to TTL FT232RL board to GND on P3P board.
5. Lead from Rx on USB to TTL FT232RL board to Tx on P3P board.
6. Lead from Tx on USB to TTL FT232RL board to Rx on P3P board.
Many thanks for you and SunsetCatcher's help.
Check you com port in device manager, com5 this com port in my system, you have another number.Hopefully someone can help me out and tell me what im doing wrong. I have followed all the instructions, connected everything as it should be and once i run the command it just sits waiting for the dm36x. the board flashes green for a little bit then turns off then flashes again.
