No connection with ipad
Hello.
I have a Phantom 3 Pro. When I go into the DJi app in my ipad mini and click "Camera" I'm not able to see the camera and all the information. Can somebody help me?
Welcome to the Forum!
How about some details...
Did it used to work?
Link light status on remote, Link light status on Phantom.
Your picture shows your Phantom is not connected to the remote.
Rod
Hello rod.
No I use it for fun. I already connected. But now my problem is that it says "No Signal"
I'm still lost, I have no idea what your stating.
Maybe these questions instead.
Did your Phantom used to work properly?
What is the Link light status on remote and the Link light status on Phantom?
Rod
This is how it looks
Looks and sounds like the most common issue with P3Ps.
I normally ask to see the LOG_AB file. Check here if you are not familiar:
This is the troubleshooting chart we routinely reference:
Reactions: JoBe and RodPad
Yes, that picture makes a lot more sense now. ;)
I still have got the same question.
Rod
@Oso,
I think you brought this up before, maybe on the wind turbine thread.
Is this a P3P problem, and not connected to P3A?
Rod
Yes used to work properly
OK, I think @Oso may ask you how long ago did you use it and did anything happen to the Phantom since then.
He going to have the better answers...
Rod
@Oso,
Rod
It’s just most common with the P3P and it’s added 4K components. It’s often due to overheating of the gimbal top (main) board since that fan on top of it is not much more than decorative and internal heat dissipation (heatsinks, etc) are lacking. That’s why we suggest over and over to always have a fan blowing on it if it’s powered up but not flying. During a long FW update or using the sim as examples.
Reactions: JoBe
OK,
P3A, P3S must not have or need a fan?
@ChristianBeuffe,
Its your turn,
How long ago did you use it and did anything happen to the Phantom since then.
Rod
OK,
@ChristianBeuffe,
Its your turn,
Rod
Yes, that’s another too common issue. It works perfectly the last time used, is put away for some length of time be it weeks or months, and then it doesn’t work. So many threads have started with, “It worked fine the last time I used it, then...” Very frustrating.
Reactions: JoBe
Hello.
I stop using the demon for about 6 months and now I'm using it again. So when I charge and connect everything again appears that problem
shimuafeni fredrik
