- Joined
- Dec 6, 2019
- Messages
- 5
- Reaction score
- 1
- Age
- 44
Hello rod.
No I use it for fun. I already connected. But now my problem is that it says "No Signal"
Looks and sounds like the most common issue with P3Ps.This is how it looks
It’s just most common with the P3P and it’s added 4K components. It’s often due to overheating of the gimbal top (main) board since that fan on top of it is not much more than decorative and internal heat dissipation (heatsinks, etc) are lacking. That’s why we suggest over and over to always have a fan blowing on it if it’s powered up but not flying. During a long FW update or using the sim as examples.@Oso,
I think you brought this up before, maybe on the wind turbine thread.
Is this a P3P problem, and not connected to P3A?
Rod
Yes, that’s another too common issue. It works perfectly the last time used, is put away for some length of time be it weeks or months, and then it doesn’t work. So many threads have started with, “It worked fine the last time I used it, then...” Very frustrating.OK,
P3A, P3S must not have or need a fan?
@ChristianBeuffe,
Its your turn,
How long ago did you use it and did anything happen to the Phantom since then.
Rod
