I bought a p3 4k used through craigslist but came with no instruction book. which app should I download for this model CE0890? It only has micro usb ports, no regular usb ports.
Yes, its true for the P34k model as was noted earlier in this thread and in the documents linked earlier in this thread.Some areas of the internet say it should do it through the wifi, and no need for the wire. Is this true?
Are you not seeing the links that @msinger posted to the manual and the quick start guide?how do I do this?
It's not possible to connect the remote controller via a wire.Some areas of the internet say it should do it through the wifi, and no need for the wire.
Yes, you must do that. Follow the steps in this guide.Am I not supposed to open my wifi on my phone an enter the code 12341234 somewhere?
Just speculating here. If you are indeed following the steps that have been provided here since post #3, perhaps the original owner changed the SSID from the default "PHANTOM3_XXXXXX" to "Dragonite"i turned everything on, and it started working, the gimbal at least. Am I not supposed to open my wifi on my phone an enter the code 12341234 somewhere?
All I see that is new is one called "Dragonite" does this have anything to do with the dji app?
I would simply try 12341234 with the Dragonite wifi network you see on your phone. If it doesnt work, I would look into resetting the SSID and password to factory defaults.possibly, and I don't know the password. What can I do?
I am at the DJI GO app, the step 3 says connect USB cable to controller and phone/tablet. I only have a micro usb port on the controller not the regular usb port. I do not have a micro to micro cable. ??
Get wifi to search for phantom on device with rc and AC on the default password which you will need to enter to conect is 12341234,you might not get pic of 34k on home screen till it conect,this is what mine does,once wifi conect p34k will come up on screenpossibly, and I don't know the password. What can I do?
