There are already 2apps supporting VR: Fpv Camera and Litchi.I kinda doubt that this will work based on how these VR goggles function. DJI would probably have to come out with a split screen app which is probably unlikely.
That's good to know !!
I have Litchi already, now I need to figure out how to make it work and what it can do![]()
Yes I do.Frogbone......Do you have the Samsung Gear VR goggles?
Why can't you use the controller buttons to start and stop recordings?In regards to Note4 and Gear VR...
Gear VR goggles will ONLY work with P3 STANDARD and P2 VISION and VISION PLUS with LITCHI.
You will need to run the Note 4 without activating the oculus software. This is done mounting the note 4 in the hack position where the micro usb port is NOT engaged. It will only work with the above 2 phantoms because they run wifi FPV and NOT cable USB for FPV.
Now the newer VR headset for the Galaxy S6, S6 edge and S6 Plus has an external micro usb. What I don't know is whether that port is data+charge or data only. If data+charge then Oculus needs to write a Gear VR app for the DJI Go app or they need an app that can emulate stereoscopic images.
The biggest hurdle will be the interaction. Eg, how to you stop and start recording if you cannot touch the screen.. etc.
your using the Samsung gear vr?You are able to use all your buttons when you are connected to VR and I'm using Litchi app VR with Phantom 3 Pro
Sent from my SM-N920C using Tapatalk
