P3 Firmware New Phantom 3 Professional
Hello
I just recently got my new Phantom 3 professional and it seems to be working fine.
However I purchased a new card and battery and now when i turn it on I get Battery Damage.
I put the old card back in along with the original battery and its fine.
Any ides how I can use the new memory card and get the other new battery to work.
Thank you.
Sent from my SM-G930V using PhantomPilots mobile app
The SD card has a BIN file that contains the firmware for the battery. If you install an SD card without the BIN file and then install a new battery, you will be unable to set the firmware for the battery. You can try installing the new battery with the old card, or copy the BIN file to the new card and try using the new battery. I recommend having the BIN file on all SD cards you use.
Reactions: Phantom Voyager
Hello.
I did a firmware update with bin file.
So now new card works and old battery. Still getting Battery Damage on second battery . When i look at the battery cells they all show good.
Any Ideas
Helen Y West
