New firmware 15/03/3016
My signal strenght decreased after the update according to healthydrones. Signal map shows poor connection during the whole flight (almost 100 minor errors). Before the uodate everything was all green! What to do?
Flew again, I'm convinced that my range has increased. Now I'll be going out to the beach to try breaking my 7400+ feet distance record.
I planned on installing the FW update this morning, but to fix another issue with my Go app update, I cleared the app's cache and forced it closed, restarted my phone and now the FW update is not showing up again.....[emoji35]
No update shown here either. Will check again now and then [emoji20]
Does this update also restrict flight around/within a nfz?
Hi there. Just updated mine.
At 50% the update failed and the P3S starded to make an auful (lowd) beep noise.
I thohgt everything was lost.
Turned off everything and repeated the update process (with the auful beep and the normal beep at the same time).
After 20 minutes, update was successfull.
Had to repair RC, did a IMU & compass calibration and hit the sky.
I can confirm than in my case I also observed an increase on range.
I`ve also notice an increase on GPS signal (before I could roughly get 6 sat locked, now I can get 9 sat easily).
Got 200 mts with good signal on a very wifi-crouded air space.
When I went cross some trees, i finally got signal lost.
The RTH function kicked on and landed safetly on my house.
Regads.
P.
If you have the patience, read the dji forum thread on the FW upgrade. Same question was asked here, and answered as a no.
(Trying to insert hyperlink here, but it's not working)
Reactions: gvsukids
just getting beeps 1234 1234 1234 over and over at 40 percent upgrading.
im now at 63 percent and my camera is going crazy. kinda funny to watch just bouncing and shaking all over
And now at 80 percent it says it failed. The app says controller is connected but bird is not.
well everything shows current versions. just recharging controls and waiting for the sun to drop some so i can actually see ****.
Yup still sucks. Really no RC signal at 100 feet?? NIIIIIIICE.
tpren3
