Need to raise my Phantom just a bit
Raymore Missouri
What are you guys using to raise your Phantom enough to clear gimble? Taller legs are out and whatever I use has to removable to fit into case. I'm thinking 4 small blocks of foam but I thought I'd ask to see if you had better ideas.
hey monte, someone here has a pair of plastic clip ons that he adds to the bottom of his legs, looks nice, i dont want longer legs either because of my case, ill try to find the post
Monte55, which Phantom do you own?
yea the ones that pb7424 showed are more like the ones i saw,,, somewhere,,, might have been on a 3d printing site, thought it was someone on boards showing a pic though, i think they were orange or red clip ons?i might go for a set of those on ebay, thank you for the link.
Monte55, would 1/2 inch more be enough to clear the gimbal? If so, you might be able to install P2V+ landing gear.
I used 4 pieces of foam I cut. Drilled a hole and then split. Total weight. 1.5 grams. $44 is crazy to lift the quad up half an inch
P2V+ landing gear is only $12.73 shipped on Amazon.
Johnboy94
