Need some expert advice on antenna rig
Like everything in life when we need something we don't or can't have it, anyway I was putting together some bits I had and wanted to make a portable setup for car etc.
Looking the setup, mainly the different pig tails used, I've gone the longest way around here [emoji23] how much signal would you anticipate I'd lose? Hopefully the postman will bring the right ends today, eliminating the jigsaw.
Total length approx half a metre.
Hi There
I'm not sure of your set-up, the coaxial cable does not look as thought it will be sufficiently "Low Loss", I,m assuming that the set up is for 5.8Ghz transition/reception
cable like this LMR400, LMR300, or RG142 will be your best bet, check this or similar links for signal loss:-
Google
Also look at this set up, probably the best there is :- MaxxUAV United Kingdom (UK)
Regards
Waylander
