Need Help: My Sticks are not performing actions as labeled !!!
Hello guys
Sorry if this sounds silly, hhhh
but i just bought my P2 + H3-3D, Gopro hero 4 black.
I flied normally without any problems, later on, a friend of mine told that i've made a mistake flying without updating the P2 and calibrating it.
that's why i connected it to the Assistant software, and up-date it, then calibrate it.
after that the P2 controller didn't start the engine when i pulled the sticks center-down.
it started the engine when i pulled the left stick left-down, and the right stick up-right.
and when i pushed the left stick UP, the P2 didn't fly, while when i push the right stick FORWARD it flies up.
so i feels like the controller sticks are missed up !!!
I'll appreciate any help guys,,,
Sounds like you need to get back on the assistant and look closely at what you've selected.
You have a very interesting problem, I'll give you that.
Welcome to the forum.
When you are through needing help, we've got cool photos/videos and Off Topic to keep you entertained.
Reactions: M. I. Haboubi
In the Assistant, under Basic/RC, there are labels beside each axis that should say "NORM" and not "REV". Click on them to toggle them.
There's also a button there to calibrate the sticks.
this what happens when i pulled both sticks center-down !!!
is it ok ??????
People have reported that after firmware upgrades the Tx becomes set to Mode 1.
In this mode the Left and Right stick Vertical channels are swapped.
Sounds like what you're describing.
It can be set back to Mode 2 in the assistant.
Here's more on Modes:
http://www.rc-airplane-world.com/rc-transmitter-modes.html
Welcome to the forum !
The first red flag would have been you already had no problems flying . absolutely no reason to update .
Dose your friend have a phantom ?
Some people have this brain wash that all devices need updated BS sometimes the updates cause problems Never Never update anything without doing some research .
Your problem sounds like something is out like above check your mod then calibrate like in the video posted above . report back let us know how it works out .
Your friend could have cost you $1500 + if he knew what he was doing he would have been able to get you back in the air so give him a smack from me :mad: .
You should probably plug your controller into the PC and run the RC Assistant software (not the Phantom Assistant). If you don't see a USB port on the bottom of your controller, then you'll find it on the inside. Unscrew the back cover, lift the bottom slightly, then pull it down away from the antenna.
Run the RC Assistant and verify the correct mode and calibration there. Then rerun the Phantom Assistant and check things again in it (with the USB cable plugged into the Phantom).
tom sauter
