NEED HELP!!!How to link Lilliput 664W with ImmersionRC 600?
I cant get my RX/Monitor Lilliput 664W to get a signal from the my P2 using the immersionRC 600 , with an iosd mini all linked with the plug and play cable. Everything is hooked up properly and all updates complete. TX switches and RX switches are matched. Any Ideas?
Re: NEED HELP!!!How to link Lilliput 664W with ImmersionRC 6
My understanding is that the 664W comes in 4 different versions, each dealing with a specific set of frequencies. Are you certain that the version you have operates on the Immersion frequencies?
Immersion frequencies are: 5740, 5760, 5780, 5800, 5820, 5840, 5860MHz
The default for the Lilliput are: 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945MHz
If you have the default version then it's not going to work.
Thank you. Through my research i found out that info as well. And since i got my monitor off ebay, thats probably what the issue is. My fault for not asking the seller what freqs were in there. Thanks again for yr reply.
And once you get the right one, you will find it is still not fully compatible with the ImmersionRC 600mW vTX. You will get very poor range and lots of break ups. So better to swap vTX than swap monitor.
Why? What is the problem between the two?
akinproplumbing
