NEED HELP!!!How to link Lilliput 664W with ImmersionRC 600?
Discussion in 'Phantom 2 Discussion' started by excap935, Jun 29, 2014.
  1. excap935
    I cant get my RX/Monitor Lilliput 664W to get a signal from the my P2 using the immersionRC 600 , with an iosd mini all linked with the plug and play cable. Everything is hooked up properly and all updates complete. TX switches and RX switches are matched. Any Ideas?
  2. rilot
    Twyford, UK
    Re: NEED HELP!!!How to link Lilliput 664W with ImmersionRC 6
    My understanding is that the 664W comes in 4 different versions, each dealing with a specific set of frequencies. Are you certain that the version you have operates on the Immersion frequencies?
    Immersion frequencies are: 5740, 5760, 5780, 5800, 5820, 5840, 5860MHz
    The default for the Lilliput are: 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945MHz
    If you have the default version then it's not going to work.
  3. excap935
    Thank you. Through my research i found out that info as well. And since i got my monitor off ebay, thats probably what the issue is. My fault for not asking the seller what freqs were in there. Thanks again for yr reply.
  4. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    And once you get the right one, you will find it is still not fully compatible with the ImmersionRC 600mW vTX. You will get very poor range and lots of break ups. So better to swap vTX than swap monitor.
  5. adanac
    NYC
    Why? What is the problem between the two?
Similar Threads - NEED HELP link Forum Date
Need help with Linking aircraft Phantom 4 Pro Help Mar 29, 2017
Need help please linking onto phantom after upgrade General Discussion Nov 29, 2016
Need help with my drone. Blinking yellow lights?? Phantom 2 Vision + Help Sep 25, 2015
Need help linking dominator v2 to phantom 2 via iosd and transmitter Phantom 2 Help May 10, 2015
Beginner Help Needed - Blinking Yellow Phantom 1 Help Oct 6, 2013
