need fatshark help!!!
I have the phantom 2 and the fatshark
I bought the plug and play cable
I have plugged the cable into the cam (phantom 2)
the two connectors into the fatshark
the gopro is connected
when I power on the phantom the fatshark powers on but i get no video in the goggles....just static
anyone have any ideas?
I'm not familiar with the plug and play cable but have you tried switching Chanel's on the goggles ? At any time have you powered up the transmitter without the antenna ?
Plug and Play Cable: DJI Phantom 2 to iOSD Mini and Fat Shark/ImmersionRC Transmitter
was told when i purchased the cable that i didn't need to hook up the iosd (plan on buying later)
i have the zenmuse H3-3D gimbal
I have tried switching the channels
both antennas are attached
it seems that iosd does have to be connected otherwise the connection between the video is broken. I cut the iosd connector out and spliced the black and yellow wire together and now I have video.....down the road when i have another 70 dollars laying around I will purchase the iosd and then reconnect the connector.
Cool glade you got it working I soldered my connections that's why I was unsure of the plug and play setup .
ctlfreak
