ND filter + rebalance, do I need to change CG?
I finally got around to rebalancing my H3-3D after adding an ND filter to my Hero4 Black. So do you normally need to change the CG settings in Phantom Assistant to compensate?
Thanks
Thanks
I did the same thing and left the settings alone. Flys perfect. The added weight is almost dead center. I would be interested to hear if anyone knows a reason why you would want to mess with your gains/settings etc.
My hero 4 on the other hand I believe to be defective. Sending it back for a replacement.
Hi Spudboy,
How did you rebalance the H3-3D - I'm planning the add the filter to mine?
TIA,
Gerry
Hi Spudboy,
TIA,
Gerry
I used hook & loop (velcro) and coins. To balance the hero 4 with a Polar pro ND filter I used a Quarter on the tilt motor metal end and a quarter on the back of the rectangular plate that holds the gopro as close to the gimbal arm as possible. If I was home, I would take a picture of it...
Originally I had stuck a coin on the servo can, but that can cause buzzing of the motor. So now I have a small lead weight on the bottom back edge of the GoPro mounting plate, nearest the servo end, and a stick on tire balancing weight on the rectangular part of the arm, directly behind the side servo.
DO NOT stick coins directly on the motors (silver part). Stick them anywhere on the black supports.
Thanks Fyod,
I had been adding coins to the back of the camera mounting bracket - I reckon lead is the answer.
G
intertronixlabel
