My phantom doesn't wan to calibrate
something is wrong with my calibration.
I with the S2, yellow shines, I do the first 360 degree rotation (horizontal), green shines
I do the 2nd 360 degree rotations (vertical) and yellow/red flashes.
Tried it on different spots, turning the other way around. Nothing changes
Have latest firmware on
what could it be?
What can I do next?
How could I check if the compas sensor is defect?
or is it a software problem and the calibration does not want to safe after execution?
can I read somehow the errors out?
Regards
Lolorek
I also noticed that one of the Battery LED's is off. Could this perhaps be somehow linked to the compas calibration?
what could it be?
What can I do next?
When multiple attempts to calibrate the compass fail, you may have a disconnected compass.
You need to go to the Sensors section of the app settings and see what it's telling you about the compass.
If you see zero there for compass data, that confirms that the compass is disconnected and won't calibrate until it's fixed.
The most common causes are a loose connector to the mainboard or one of the fine wires in the landing gear is broken.
no, the software shows some different figures there
