Multi-Battery Charger plug issue
I have a 3 battery charger for my 3 batteries. All of the sudden tonight, the power cord won’t stay attached to the unit. Keeps popping right off. It used to click in place and stay secure till charging was complete. Still connects to individual batteries with no problem. Anyone ever had this happen? Last time I used it, it was fine. Seems odd that plug receptacle would wear out all at once.
You got a picture or a model# of your charger?
Rod
Rod
OK....would you prefer the cord stays connected all the time to the charger unit?
IF.....so a single drop of super glue to it's top edge when its inserted...ONE drop......No more.
Reactions: Beefy1 and RodPad
I may have to do that. I did use the cord to charge a single battery occasionally for quick flights if I knew it would be awhile before I would use the other two. It felt like a piece of the connector dropped off or something because I no longer get that “snap-in” feeling upon connecting. But there is nothing missing that I can tell. Maybe the connector just finally wore out.
Reactions: MotorCycle-Man
