Move the H3-3D further out to not see props
Beverly Hills, CA
Hi! Is there a way to add a plate to have the H3-3d or 2D further out so we wouldn't see the props or the legs?
you're better of shooting in a narrower video mode. most people dont use "wide", but instead use "medium" on their gopro's.
you can also shoot at 1440p and then crop the top in post.
You can also adjust the Vertical and horiz. Gain setting in the Phantom Assistant software so the gimbal is slightly pointed down by a couple degrees when you have the tilt lever all the way up.
