Micro SD Card Format error and no files shown.
I am not having a good time of late with my various issues.
Now I have an micro SD card with numerous flights on it showing as not formated. I have tried recovering files using recovery with 2 different software but even that says no files on the card. The last flight I took my phone only shows 2 minutes of whereas the card had 10 minutes on it (I checked before it corrupted).
Anyone else had an issue like this?
Wondering if I should re-format and then see if I can then recover the files via software?
Don't reformat it if you are still trying to get the files off.
I would consider a program called getdataback. I have used it before on corrupt cards and it still pulled data off.
If the files are not important, just reformat the card, in the drone or on your PC/Mac.
I have had issues where a card formatted on a mac "exfat" would not work on a Mavic or P4 Pro. Just got a card error on the main screen. Just reformatted it in the drone and it was fine.
Paul Caldwell
Thanks - I will try the software you suggest but the 2 before both said there were no files to find.
Do you, or anyone know if the full video file is recoverable from anywhere else? My phone has 2 minutes but as mentioned the card had 10 minutes on it. Likewise I filmed again using this card and see no evidence of that on my phone. After this the drone was showing video transmission error when I next tried to use it. Put a new sd card in and fine again, so I clearly this was when it got corrupted.
