Maximum flight distance reached
This is so frustrating!!
I flew then changed battery, and I got that error.
I deleted the app on iOS then reloaded it. The bird worked fine!
Then again as I switched batteries, same error..
"Maximum flight distance & altitude reached"
HELP PLEASE
Are you running DJI Go? That happened to me after the most recent firmware upgrade when I tried to start up with Litchi. This upgrade requires that when you first start your bird, that DJI Go is running (ie. so you can see status of all the sensors so that if there's any problems, you'll see it in Go). Then you can close out Go and start up any third party software such as Litchi.
@CrashCraft - tks I'll try this in the morning again. Will be sure to update you all when I do.. tks again.. keep u posted on the results [emoji106]
Hi, I have the same issue since last firmware update. I’ve realised that changing a cable between controller and iphone/ipad helps. But now and than fault comes up again. Couldn’t make FPV working any more after update. I mean it is working but with this stupid range restriction. DJI staffed it up big time.
TK-62119
