Lost P3S http://www.phantomhelp.com/LogViewer/1HXNXA59WSRDWZQ0HPES/
Can you describe more clearlier please? Did you wait for your phantom? According to the log, the phantom 3 went into go home mode after signal-lost. When you took off, was your home-point set at right place? Did you check that area, where you lost your phantom 3? Maybe a power-failure and the phantom 3 crashed?
Absolutely, It was common to get weak signal warnings so I wasn't that concerned when they start just minutes into my flights. After a few sec. Of weak sig warning, it degraded to lost signal with video feed and ac control lost. I started to close the gap in hopes of re-aquiring control but nothing. I shut down the radio in hopes that failsafe would initialize but I never saw it again.
Absolutely, It was common to get weak signal warnings so I wasn't that concerned when they start just minutes into my flights. After a few sec. Of weak sig warning, it degraded to lost signal with video feed and ac control lost. I started to close the gap in hopes of re-aquiring control but nothing. I shut down the radio in hopes that failsafe would initialize but I never saw it again. Home point was set. And after lost signal, the ac turned to the Home point, accelerated to 5.5 mph and vanished..
I do not think that the phantom 3 hit something as the height was about 400ft and when i look at the map, there should be no buildings that can reach 400ft. According to the logviewer (healthydrones) the home-point was that place, where you take off with that phantom.
here
I would start to ask around, if someone saw your drone. Maybe power-failure, battery not sitting well and lead to shut down etc. We can only speculate.
here
Thank you for your time and input. The search will continue...
@Dennis3257
So far I haven't seen a clue yet.
But, Why would the dates from these files be 10 days old?
Rod
After sending DJI Flight logs, I resynced because there were some she couldn't find. The date you see is the last modified file date.
BanksBoyd
