- Joined
- Apr 8, 2017
- Messages
- 30
- Reaction score
- 2
- Age
- 64
Absolutely, It was common to get weak signal warnings so I wasn't that concerned when they start just minutes into my flights. After a few sec. Of weak sig warning, it degraded to lost signal with video feed and ac control lost. I started to close the gap in hopes of re-aquiring control but nothing. I shut down the radio in hopes that failsafe would initialize but I never saw it again.Can you describe more clearlier please? Did you wait for your phantom? According to the log, the phantom 3 went into go home mode after signal-lost. When you took off, was your home-point set at right place?
Absolutely, It was common to get weak signal warnings so I wasn't that concerned when they start just minutes into my flights. After a few sec. Of weak sig warning, it degraded to lost signal with video feed and ac control lost. I started to close the gap in hopes of re-aquiring control but nothing. I shut down the radio in hopes that failsafe would initialize but I never saw it again. Home point was set. And after lost signal, the ac turned to the Home point, accelerated to 5.5 mph and vanished..Can you describe more clearlier please? Did you wait for your phantom? According to the log, the phantom 3 went into go home mode after signal-lost. When you took off, was your home-point set at right place?
Thank you for your time and input. The search will continue...I do not think that the phantom 3 hit something as the height was about 400ft and when i look at the map, there should be no buildings that can reach 400ft. According to the logviewer (healthydrones) the home-point was that place, where you take off with that phantom.
here
I would start to ask around, if someone saw your drone. Maybe power-failure, battery not sitting well and lead to shut down etc. We can only speculate.
