Live feed issue on the p3s
The live feed is slow to catch up p3 flies fine camera moves ok to help please did do a uninstall and reinstall of app but did not fix it on adroid
Thanks
Thanks
Try changing camera settings or transmission channel,dont have to fly to test just hold your drone and go through and find one that not glitching or pauseing
Thanks did put a filter on the camera would that of automatically change camra setting
What Android device are you using?
Under developer options, try setting "Force GPU rendering" to on. You shouldn't see much of a difference (if any) on faster devices, but it may help out on older devices. Your device may also have a performance mode, you can play with those settings.
If you can change the screen resolution, a lower resolution will take less CPU time to update the screen.
Another option would be to turn off cache recording in the DJI Go app.
most
