Litchi Waypoint: one mission takes off, one doesn't
I have two separate missions. One mission loads to the P4P fine and the drone takes off and does it's mission. The other mission acts like it loads but then the drone just sits there. I've looked over both mission to see what might be the difference that prevents one from taking off while the other works fine. I've tried taking off manually and then start the mission but that didn't work
All equipment is the same between missions. The attempts are within seconds of each other. One missions flies, one doesn't. The area flown is basically the same.
Any thoughts about what might cause this failure and how to fix it?
Thank you.
