Something else to think about, I was messing around with a low and slow mission, the goal was to test battery efficiency and make a neat video around my house, etc.
Because of where I live I have never found a good take of point. I live on a hill and have many trees. (Fir Mountain Road)
What I noticed, it maybe obvious to some.
You set WP#1 at (8') then your WP#2 etc at 8' above ground level. Where the home point is set at zero, yep.
But then I start the phantom in a different location like 30' away and now the elevation home point is now 10' higher. Then WP#1 is not 8' above ground level, it is now 28'. Anyways I think you got my point.
I was also getting enough GPS variances, to scrap the plan. I would stop the flight for a tree, move a couple of way points, try it again, then its headed for a tree before I get to the waypoints that I moved.
I did get a mission that is 15 mins long at 1.5 mph, not at all what I wanted, I would still see a variation of 10' GPS, I had to follow it around and still cancel it at times. Before I had going around trees and sometimes it would be under them, not on purpose.
Agreed with above, if I use auto take off and auto landing in the mission. It lifts about 4-6' then it heads to the first WP. My first WP for a real mission I use 100m, and stay at 100m AGL, then fine tune later.
My P3S found a Phantom Magnet, (220' Pine Tree). When the magnetism quit. The working Phantom that I could see the camera view, start and stop motors until the battery died. It was in five pieces.
When it lands I set up the last three way points over near the landing spot. 100m, 50m, 25m, 10m. It comes down really fast until it goes into Auto Land which is a much slower speed, it still can be entertaining to hand catch.
Rod
