yes, but only the logs that are V2....Even better... the latest beta allows direct exporting to healthydrones.
Flight Path would be nice on Litchi, I never cared for it, until I lost my unit in the sun....I am going to try that. I figured it had something to do with DJI Go settings. I turned on Multi Flight Mode, but I never thought to go to F in DJI so I could turn on IOC. I like Litchi but there are some things in DJI Go I like too. I would like to see the on screen flight path tracking like DJI has. Also, does anyone know if there is a way to calibrate the radar on Litchi (Or GO)? It always seems to think I am pointing my controller about 40 degrees off of its actual orientation.
So is does the litchi still require developer drivers or will it work out of the box?
Should the DJI GO app be running in the background each time Litchi is running? Or can Litchi run once the P3A/P is set up by DJI GO?In DJI GO app
Make sure Multiflight mode is on.
Make sure IOC is on.
And then in Litchi,
Switch to F mode and then try again.
Latest public firmware is required.will Litchi work with 1.3.2 or do I need to have 1.4.10? I am having stability issues with 1.4.10 and went back to 1.3.2…P3P wouldn't fly a straight line on 1.4.10 and was drifting in a hover
No, the DJI Go app should be completely closed when running Litchi.Should the DJI GO app be running in the background each time Litchi is running? Or can Litchi run once the P3A/P is set up by DJI GO?
Thanks for the reply...anyone having "No Signal" issues in Litchi where u lose video feed but not control of the P3? I am having these issues with the DJI Go App and wondering if switching to Litchi will fix this?
+1If you are getting no signal at 10 ft, I would suspect either a problem with your device or a problem with your cable connecting your device. What does the signal strength for video show before and after the error?
