Litchi android issue in F mode - P3S
Hello
I am having problems with the litchi app to enter in F modes.
I put the switch in F position but litchi does not recognize. With the other two positions (P-Atti and Atti) it works and recognizes them perfectly. Even having the switch in F position when I pulse in one F mode gives me the message that I should put the switch in position F.
Discard that it is a physical problem of the transmitter because with the app DJI GO works perfectly in all three positions.
Until now I had never had this issue and I have been using Litchi since 2016 without any failures until today.
My model is a Phantom 3 Standard and the Litchi app is updated to the latest Android OS version.
I hope some guru around here can help me. Thanks in advance and good flights ...
That is one I have not heard before. Did you try powering up in F mode, then switch back and forth after the home point has been set?
Thanks for the info.
I will try to do what you tell me and as soon as I do I will post the result.
Hi everyone, I'll be back to share what happened with my rare failure.
I tried as you told me to turn on the switch in F mode and after the "heating IMU"... Yes! "F-GPS" appeared I was able to use the functions without problem.
It is quite rare but the issue seems as resolved.
hcashmore11
