Litchi and FPV
Can someone help me figure out when I start Litchi up everything looks great. But when I plug the HDMI cable into the controller the screen on my tablet goes black. And just as soon as unplug the HDMI the screen comes back.
Ron
You need to enable simultaneous output to HDMI and tablet in the GO app. (Don't know if you can enable it in Litchi, as I haven't used it)
Don't know....you'll have to wait for an answer from a Litchi user!
I would imagine that once it's enabled in the GO app it should then work, but that's only a guess.
I don't think Litchi works with the HDMI output module. I haven't tried it.
Litchi says it does. There's a "double output HDMI" setting available.
So if i have the fatsharks plugged into the hdmi and the tablet plugged into the usb they both should work. Am i understanding what you are saying correctly?
I don't remember if there is an option about double output, in Litchi for IOS.
Maybe it's there but I did nothing, I just putted the hdmi cable inside module and inside Skyzone goggles and it worked.
I remember that I had activated double output in DJI Go app.
Tomorrow I'll check the Litchi settings and I'll update the thread.
It should work normally, but try to start the app after that hdmi and usb cable are connected to devices.
And, of course, if you have the "double output" option, activate it.
Thank you sir
hirehackers
