DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2014-05-30 6:44:26 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4034816 Bytes = 3.8 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-GSPv2-Kernel-1.0-rc3(2014-05-30 14:45)
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 PREEMPT Fri May 30 14:44:25 HKT 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44456KB available (3644K code, 446K data, 116K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.030000] EVM: tvp5146 SD video input
[ 0.110000] bio: create slab <bio-0> at 0
[ 0.110000] DM365 IPIPE initialized in Continuous mode
[ 0.120000] SCSI subsystem initialized
[ 0.120000] usbcore: registered new interface driver usbfs
[ 0.120000] usbcore: registered new interface driver hub
[ 0.120000] usbcore: registered new device driver usb
[ 0.130000] vpss vpss: dm365_vpss vpss probed
[ 0.130000] vpss vpss: dm365_vpss vpss probe success
[ 0.130000] dm365_afew_hw_init
[ 0.140000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.140000] VPBE Encoder Initialized
[ 0.140000] cfg80211: Using static regulatory domain info
[ 0.140000] cfg80211: Regulatory domain: US
[ 0.140000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.140000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.140000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.140000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.140000] cfg80211: Calling CRDA for country: US
[ 0.140000] LogicPD encoder initialized
[ 0.140000] Switching to clocksource timer0_1
[ 0.150000] musb_hdrc: version 6.0, pio, host, debug=0
[ 0.170000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[ 0.170000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.170000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.170000] usb usb1: configuration #1 chosen from 1 choice
[ 0.170000] hub 1-0:1.0: USB hub found
[ 0.170000] hub 1-0:1.0: 1 port detected
[ 0.170000] NET: Registered protocol family 2
[ 0.170000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.170000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.170000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.170000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.170000] TCP reno registered
[ 0.170000] NET: Registered protocol family 1
[ 0.170000] RPC: Registered udp transport module.
[ 0.170000] RPC: Registered tcp transport module.
[ 0.170000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.180000] kfile init
[ 0.180000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.180000] msgmni has been set to 86
[ 0.190000] alg: No test for stdrng (krng)
[ 0.190000] io scheduler noop registered (default)
[ 0.220000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[ 0.230000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[ 0.230000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.250000] davincifb davincifb.0: dm_osd1_fb: Initial window configuration is invalid.
[ 0.250000] davincifb davincifb.0: dm_osd1_fb: 1920x1080x4@0,0 with framebuffer size 4050KB
[ 0.250000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[ 0.310000] venc off init
[ 0.310000] hdmi status init
[ 0.310000] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 0.310000] DM365 IPIPEIF probed
[ 0.320000] imp serializer initialized
[ 0.320000] davinci_previewer initialized
[ 0.320000] davinci_resizer initialized
[ 0.320000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.330000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.810000] console [ttyS0] enabled
[ 0.810000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.820000] brd: module loaded
[ 0.820000] at24 1-0050: 32768 byte 24c256 EEPROM (writable)
[ 0.900000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.910000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.920000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.920000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.930000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.940000] 0x000000000000-0x000008000000 : "all"
[ 0.950000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 0.960000] UBI: attaching mtd2 to ubi0
[ 0.960000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.970000] UBI: logical eraseblock size: 126976 bytes
[ 0.970000] UBI: smallest flash I/O unit: 2048
[ 0.980000] UBI: sub-page size: 512
[ 0.980000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.990000] UBI: data offset: 4096
[ 1.120000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[ 1.270000] usb 1-1: configuration #1 chosen from 1 choice
[ 1.270000] hub 1-1:1.0: USB hub found
[ 1.280000] hub 1-1:1.0: 2 ports detected
[ 1.510000] UBI: attached mtd2 to ubi0
[ 1.510000] UBI: MTD device name: "filesystem"
[ 1.520000] UBI: MTD device size: 113 MiB
[ 1.520000] UBI: number of good PEBs: 904
[ 1.530000] UBI: number of bad PEBs: 0
[ 1.530000] UBI: max. allowed volumes: 128
[ 1.540000] UBI: wear-leveling threshold: 4096
[ 1.540000] UBI: number of internal volumes: 1
[ 1.550000] UBI: number of user volumes: 1
[ 1.550000] UBI: available PEBs: 0
[ 1.560000] UBI: total number of reserved PEBs: 904
[ 1.560000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.570000] UBI: max/mean erase counter: 63/1
[ 1.570000] UBI: image sequence number: 1092381712
[ 1.580000] UBI: background thread "ubi_bgt0d" started, PID 349
[ 1.590000] console [netcon0] enabled
[ 1.590000] netconsole: network logging started
[ 1.590000] Initializing USB Mass Storage driver...
[ 1.600000] usbcore: registered new interface driver usb-storage
[ 1.610000] USB Mass Storage support registered.
[ 1.610000] usbcore: registered new interface driver usbtest
[ 1.620000] i2c /dev entries driver
[ 1.620000] Linux video capture interface: v2.00
[ 1.630000] ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
[ 1.640000] ths7303 1-002c: ths7303 write failed
[ 1.640000] ths7303: probe of 1-002c failed with error -121
[ 1.650000] tvp5150_init
[ 1.650000] vpfe_init
[ 1.650000] vpfe-capture: vpss clock vpss_master enabled
[ 1.660000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.670000] vpfe-capture vpfe-capture: video device registered
[ 1.670000] tvp5150_probe
[ 1.680000] tvp5150 1-005d: tvp5150 1-005d decoder driver registered !!
[ 1.680000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[ 1.690000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
[ 1.700000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.700000] DM365 ISIF is registered with vpfe.
[ 1.710000] Trying to register davinci display video device.
[ 1.720000] layer=c17f7000,layer->video_dev=c17f7164
[ 1.720000] Trying to register davinci display video device.
[ 1.730000] layer=c17f7400,layer->video_dev=c17f7564
[ 1.740000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[ 1.740000] watchdog watchdog: heartbeat 1 sec
[ 1.750000] TCP cubic registered
[ 1.750000] NET: Registered protocol family 17
[ 1.760000] lib80211: common routines for IEEE802.11 drivers
[ 1.760000] ksocket init
[ 1.790000] Clocks: disable unused mmcsd0
[ 1.790000] Clocks: disable unused mmcsd1
[ 1.790000] Clocks: disable unused spi0
[ 1.790000] Clocks: disable unused spi1
[ 1.790000] Clocks: disable unused spi2
[ 1.790000] Clocks: disable unused spi3
[ 1.790000] Clocks: disable unused spi4
[ 1.790000] Clocks: disable unused pwm0
[ 1.790000] Clocks: disable unused pwm1
[ 1.790000] Clocks: disable unused pwm2
[ 1.790000] Clocks: disable unused pwm3
[ 1.790000] Clocks: disable unused timer1
[ 1.790000] Clocks: disable unused timer3
[ 1.790000] Clocks: disable unused emac
[ 1.790000] Clocks: disable unused voice_codec
[ 1.790000] Clocks: disable unused asp0
[ 1.790000] Clocks: disable unused rto
[ 1.790000] Clocks: disable unused mjcp
[ 1.870000] nnnn===0
[ 1.870000] davinci_emac_probe: using random MAC addr: 46:40:56:47:74:4c
[ 1.880000] emac-mii: probed
[ 1.920000] UBIFS: recovery needed
[ 1.970000] UBIFS: recovery completed
[ 1.970000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.980000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 1.980000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.990000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 2.000000] UBIFS: default compressor: lzo
[ 2.000000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.010000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 2.010000] Freeing init memory: 116K
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>GSPv2<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Filesystem Product Vesion : DJI-GSPv2-Filesystem-1.0-rc3(2014-06-05)
Runing /etc/init.d/rcS
[ 3.800000] CMEMK module: built on Jan 22 2014 at 14:52:00
[ 3.820000] Reference Linux version 2.6.32
[ 3.820000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 3.840000] allocated heap buffer 0xc7000000 of size 0x4400000
[ 3.870000] heap fallback enabled - will try heap if pool buffer is not available
[ 3.870000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 3.880000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 3.890000] cmemk initialized
[ 3.920000] IRQK module: built on Jan 22 2014 at 14:52:01
[ 3.940000] Reference Linux version 2.6.32
[ 3.940000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 3.960000] irqk initialized
[ 4.010000] EDMAK module: built on Jan 22 2014 at 14:52:02
[ 4.010000] Reference Linux version 2.6.32
[ 4.030000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 4.700000] usb 1-1.1: new high speed USB device using musb_hdrc and address 3
[ 4.830000] usb 1-1.1: configuration #1 chosen from 1 choice
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
sulogin: no password entry for root
umount: can't umount /mnt/usb: No such file or directory
login[491]: root login on 'ttyS0'
rmdir: '/mnt/usb': No such file or directory
#Process /etc/profile...
root@Dji-Pro:~#
USBClient version 1.0.23
ReadSize = 2048 Timeout = 90
init libusb successed!!!
!!!!!!!!!!!!!!!!!!!!!!! open 68013 succeed VENDOR_ID = 0x0547
Claiming libusb_claim_interface 68013 successed
usbmuxd_subscribe OK OK
watchdog timeout:5
latency1:33332
latency2:33000
latency3:30000
displaybuffnum1:4
displaybuffnum2:9
start decode stream from 68013
decode init ok, main thread exit
Osd_Init_Font succeed
[ 9.660000] pinmux1:0x00185555
[ 9.660000] pinmux4:0x1155fdff
[ 9.720000] pinmux1:0x00185555
[ 9.720000] pinmux4:0x1155fdff
[ 9.830000] pinmux1:0x00185555
[ 9.830000] pinmux4:0x1155fdff
[ 9.890000] pinmux1:0x00185555
[ 9.890000] pinmux4:0x1155fdff
[ 9.950000] pinmux1:0x00185555
[ 9.950000] pinmux4:0x1155fdff
[ 11.980000] PCLK = 0 -> 0
[ 11.980000] HTotal = 0 -> 1650
[ 11.980000] VTotal = 0 -> 750
[ 11.990000] ScanMode = I -> P
[ 12.000000] PCLK = 0,(1650x750) PROGRESS CHANGE MODE
[ 12.000000] VIC = 4
root@Dji-Pro:~#
root@Dji-Pro:~#
