lightbridge firmware PROBLEM (and solution) - firmware version not found by dji assistant tool
Do you think that this firmware is the same there is on lightbridge for boot? Maybe there are also some DJI code on Nand. And DJI don't do help at all...
william, the tool is in the SDK, the firmware is our firmware, that we backup on my working LB.
andrew decrypted it.
did you read the thread?
of course it is possible that the flash contains more data than what we have in our files. for this reason we need a full backup of the flash, from a working LB.
Yes,I mean this. Not only code, but maybe some setting (like U-boot environment).
I assume that for some reason, the fault have deleted all from chip, we can't know what is deleted. We must restore everything.
Actually, my unit is in assistance, just it is back I can try to backup flash, I hope you can help me, I'm not able to do this, but I can learn.
The backup that we have was made on a working LB.
I'm not sure if andrew correctly decrypted it and i don't know if the files that we have are corrupted.
actually in BOOTME mode i launched the flash tool and i was able to write the bootloader (UBL file) and the u-boot, but now when i go in nand mode (default mode without jumper) there is no print on the serial line. this means that i flashed wrong file or i fhashed it in the wrong location. fortunately the BOOTME MODE is readonly, so i can Always write the flash, if i find the write data to flash and the correct location in the memory.
Sub'd
I need someone with a working LB to connect to the upgrade port, enable the serial and check if the following commands are available:
nand
flash
mtd
dd
nanddump
or some other command that starts with that.
if commands are available, you can run them without parameters in order to show the help (don't do it for dd cause I still know the syntax)
another thing to check is the file /opt/dji/bin/mtdwritefile
is it a script or a binary file? someone should edit it and see if it contains unreadable characters or Linux script.
P.S.: I also found another jtag programmer that could be good: BUS PIRATE ( Bus Pirate - DP )
here it is shown how to connect to the board: Bus Pirate I/O Pin Descriptions - DP
and here it is detailed the support of openocd for our LB (LB is made basically with a Texas Instruments daVinci DM36x board, to be more specific i think it is a DM365 board) : Debugging on DaVinci using OpenOCD - Texas Instruments Wiki
note: openocd is a opensocurce software that allows to flash firmware using many interfaces (commonly JTAG and UART) and for many devices. it is also used generally to flash firmware over arduino boards.
and here it is detailed (para 12.5.2) how to dump the memory with openocd and jtag interface:
OpenOCD User’s Guide: Flash Commands
inside SDK there is the default bootloader (UBL). I uploaded it (file ubl_DM36x_ARM432_DDR340_OSC24_NAND.bin) and, removing the BSEL jumper i obtain the following log during boot:
Code:
DM365_432 DDR 340 initialization passed!
Booting TI User Boot Loader
  UBL Version: 1.65
  UBL Flashtype: NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
  DONE
Jumping to entry point at 0x81080000.
In my opinion this demonstrates that the UBL file that andrew decrypted is malformed.
observing the difference between the ubl in sdk and ubl received from andrew, i found at the beginning, 0x800 bytes "more" and then the beginning of the same "header". so i removed from our file the beginning and then i flashed it.
now when i start the board I get this log:
Code:
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Uboot Checksum:0x3A4D8A01
Actua Checksum:0x3A4D8A01
it seems that now the bootloader is good.
looking in the application file (u-boot.img) received from andrew I found the same strange sequence of 0x800 bytes.
I removed them from the beginning of the file, then I tried to flash it.
this is what now i obtain on the serial:
Code:
BootMode = NAND
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR:  297 MHz
I2C:  ready
DRAM:  128 MiB
NAND:  128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net:  Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
  Image Name:  Linux-2.6.32.17-davinci1
  Created:  2014-05-30  6:44:26 UTC
  Image Type:  ARM Linux Kernel Image (uncompressed)
  Data Size:  4034816 Bytes = 3.8 MiB
  Load Address: 80008000
  Entry Point:  80008000
  Loading Kernel Image ... OK
OK
Starting kernel ...
[  0.000000] Kernel Product Vesion : DJI-GSPv2-Kernel-1.0-rc3(2014-05-30 14:45)
[  0.000000] Linux version 2.6.32.17-davinci1 (root@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #8 PREEMPT Fri May 30 14:44:25 HKT 2014
[  0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[  0.000000] CPU: VIVT data cache, VIVT instruction cache
[  0.000000] Machine: DaVinci DM36x EVM
[  0.000000] Memory policy: ECC disabled, Data cache writeback
[  0.000000] DaVinci dm36x_rev1.2 variant 0x8
[  0.000000] Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 12192
[  0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[  0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[  0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[  0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[  0.000000] Memory: 48MB = 48MB total
[  0.000000] Memory: 44456KB available (3644K code, 446K data, 116K init, 0K highmem)
[  0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[  0.000000] Hierarchical RCU implementation.
[  0.000000] NR_IRQS:245
[  0.000000] Console: colour dummy device 80x30
[  0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[  0.000000] Mount-cache hash table entries: 512
[  0.000000] CPU: Testing write buffer coherency: ok
[  0.000000] DaVinci: 8 gpio irqs
[  0.000000] NET: Registered protocol family 16
[  0.030000] EVM: tvp5146 SD video input
[  0.110000] bio: create slab <bio-0> at 0
[  0.110000] DM365 IPIPE initialized in Continuous mode
[  0.120000] SCSI subsystem initialized
[  0.120000] usbcore: registered new interface driver usbfs
[  0.120000] usbcore: registered new interface driver hub
[  0.120000] usbcore: registered new device driver usb
[  0.130000] vpss vpss: dm365_vpss vpss probed
[  0.130000] vpss vpss: dm365_vpss vpss probe success
[  0.130000] dm365_afew_hw_init
[  0.140000] ch0 default output "COMPOSITE", mode "PAL"
[  0.140000] VPBE Encoder Initialized
[  0.140000] cfg80211: Using static regulatory domain info
[  0.140000] cfg80211: Regulatory domain: US
[  0.140000]  (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[  0.140000]  (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[  0.140000]  (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[  0.140000]  (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[  0.140000]  (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[  0.140000]  (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[  0.140000]  (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[  0.140000] cfg80211: Calling CRDA for country: US
[  0.140000] LogicPD encoder initialized
[  0.140000] Switching to clocksource timer0_1
[  0.150000] musb_hdrc: version 6.0, pio, host, debug=0
[  0.170000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[  0.170000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[  0.170000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[  0.170000] usb usb1: configuration #1 chosen from 1 choice
[  0.170000] hub 1-0:1.0: USB hub found
[  0.170000] hub 1-0:1.0: 1 port detected
[  0.170000] NET: Registered protocol family 2
[  0.170000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[  0.170000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[  0.170000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[  0.170000] TCP: Hash tables configured (established 2048 bind 2048)
[  0.170000] TCP reno registered
[  0.170000] NET: Registered protocol family 1
[  0.170000] RPC: Registered udp transport module.
[  0.170000] RPC: Registered tcp transport module.
[  0.170000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  0.180000] kfile init
[  0.180000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[  0.180000] msgmni has been set to 86
[  0.190000] alg: No test for stdrng (krng)
[  0.190000] io scheduler noop registered (default)
[  0.220000] davincifb davincifb.0: dm_osd0_fb: Initial window configuration is invalid.
[  0.230000] davincifb davincifb.0: dm_osd0_fb: 1920x1080x16@0,0 with framebuffer size 8100KB
[  0.230000] davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 10KB
[  0.250000] davincifb davincifb.0: dm_osd1_fb: Initial window configuration is invalid.
[  0.250000] davincifb davincifb.0: dm_osd1_fb: 1920x1080x4@0,0 with framebuffer size 4050KB
[  0.250000] davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 10KB
[  0.310000] venc off init
[  0.310000] hdmi status init
[  0.310000] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[  0.310000] DM365 IPIPEIF probed
[  0.320000] imp serializer initialized
[  0.320000] davinci_previewer initialized
[  0.320000] davinci_resizer initialized
[  0.320000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[  0.330000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[  0.810000] console [ttyS0] enabled
[  0.810000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[  0.820000] brd: module loaded
[  0.820000] at24 1-0050: 32768 byte 24c256 EEPROM (writable)
[  0.900000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[  0.910000] Creating 4 MTD partitions on "davinci_nand.0":
[  0.920000] 0x000000000000-0x0000004a0000 : "bootloader"
[  0.920000] 0x0000004a0000-0x000000e00000 : "kernel"
[  0.930000] 0x000000e00000-0x000007f00000 : "filesystem"
[  0.940000] 0x000000000000-0x000008000000 : "all"
[  0.950000] davinci_nand davinci_nand.0: controller rev. 2.3
[  0.960000] UBI: attaching mtd2 to ubi0
[  0.960000] UBI: physical eraseblock size:  131072 bytes (128 KiB)
[  0.970000] UBI: logical eraseblock size:  126976 bytes
[  0.970000] UBI: smallest flash I/O unit:  2048
[  0.980000] UBI: sub-page size:  512
[  0.980000] UBI: VID header offset:  2048 (aligned 2048)
[  0.990000] UBI: data offset:  4096
[  1.120000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[  1.270000] usb 1-1: configuration #1 chosen from 1 choice
[  1.270000] hub 1-1:1.0: USB hub found
[  1.280000] hub 1-1:1.0: 2 ports detected
[  1.510000] UBI: attached mtd2 to ubi0
[  1.510000] UBI: MTD device name:  "filesystem"
[  1.520000] UBI: MTD device size:  113 MiB
[  1.520000] UBI: number of good PEBs:  904
[  1.530000] UBI: number of bad PEBs:  0
[  1.530000] UBI: max. allowed volumes:  128
[  1.540000] UBI: wear-leveling threshold:  4096
[  1.540000] UBI: number of internal volumes: 1
[  1.550000] UBI: number of user volumes:  1
[  1.550000] UBI: available PEBs:  0
[  1.560000] UBI: total number of reserved PEBs: 904
[  1.560000] UBI: number of PEBs reserved for bad PEB handling: 9
[  1.570000] UBI: max/mean erase counter: 63/1
[  1.570000] UBI: image sequence number: 1092381712
[  1.580000] UBI: background thread "ubi_bgt0d" started, PID 349
[  1.590000] console [netcon0] enabled
[  1.590000] netconsole: network logging started
[  1.590000] Initializing USB Mass Storage driver...
[  1.600000] usbcore: registered new interface driver usb-storage
[  1.610000] USB Mass Storage support registered.
[  1.610000] usbcore: registered new interface driver usbtest
[  1.620000] i2c /dev entries driver
[  1.620000] Linux video capture interface: v2.00
[  1.630000] ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
[  1.640000] ths7303 1-002c: ths7303 write failed
[  1.640000] ths7303: probe of 1-002c failed with error -121
[  1.650000] tvp5150_init
[  1.650000] vpfe_init
[  1.650000] vpfe-capture: vpss clock vpss_master enabled
[  1.660000] vpfe-capture vpfe-capture: v4l2 device registered
[  1.670000] vpfe-capture vpfe-capture: video device registered
[  1.670000] tvp5150_probe
[  1.680000] tvp5150 1-005d: tvp5150 1-005d decoder driver registered !!
[  1.680000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[  1.690000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
[  1.700000] vpfe_register_ccdc_device: DM365 ISIF
[  1.700000] DM365 ISIF is registered with vpfe.
[  1.710000] Trying to register davinci display video device.
[  1.720000] layer=c17f7000,layer->video_dev=c17f7164
[  1.720000] Trying to register davinci display video device.
[  1.730000] layer=c17f7400,layer->video_dev=c17f7564
[  1.740000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
[  1.740000] watchdog watchdog: heartbeat 1 sec
[  1.750000] TCP cubic registered
[  1.750000] NET: Registered protocol family 17
[  1.760000] lib80211: common routines for IEEE802.11 drivers
[  1.760000] ksocket init
[  1.790000] Clocks: disable unused mmcsd0
[  1.790000] Clocks: disable unused mmcsd1
[  1.790000] Clocks: disable unused spi0
[  1.790000] Clocks: disable unused spi1
[  1.790000] Clocks: disable unused spi2
[  1.790000] Clocks: disable unused spi3
[  1.790000] Clocks: disable unused spi4
[  1.790000] Clocks: disable unused pwm0
[  1.790000] Clocks: disable unused pwm1
[  1.790000] Clocks: disable unused pwm2
[  1.790000] Clocks: disable unused pwm3
[  1.790000] Clocks: disable unused timer1
[  1.790000] Clocks: disable unused timer3
[  1.790000] Clocks: disable unused emac
[  1.790000] Clocks: disable unused voice_codec
[  1.790000] Clocks: disable unused asp0
[  1.790000] Clocks: disable unused rto
[  1.790000] Clocks: disable unused mjcp
[  1.870000] nnnn===0
[  1.870000] davinci_emac_probe: using random MAC addr: 46:40:56:47:74:4c
[  1.880000] emac-mii: probed
[  1.920000] UBIFS: recovery needed
[  1.970000] UBIFS: recovery completed
[  1.970000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[  1.980000] UBIFS: file system size:  110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[  1.980000] UBIFS: journal size:  9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[  1.990000] UBIFS: media format:  w4/r0 (latest is w4/r0)
[  2.000000] UBIFS: default compressor: lzo
[  2.000000] UBIFS: reserved for root:  0 bytes (0 KiB)
[  2.010000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[  2.010000] Freeing init memory: 116K
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>GSPv2<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Filesystem Product Vesion : DJI-GSPv2-Filesystem-1.0-rc3(2014-06-05)
Runing /etc/init.d/rcS
[  3.800000] CMEMK module: built on Jan 22 2014 at 14:52:00
[  3.820000]  Reference Linux version 2.6.32
[  3.820000]  File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[  3.840000] allocated heap buffer 0xc7000000 of size 0x4400000
[  3.870000] heap fallback enabled - will try heap if pool buffer is not available
[  3.870000] CMEM Range Overlaps Kernel Physical - allowing overlap
[  3.880000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[  3.890000] cmemk initialized
[  3.920000] IRQK module: built on Jan 22 2014 at 14:52:01
[  3.940000]  Reference Linux version 2.6.32
[  3.940000]  File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[  3.960000] irqk initialized
[  4.010000] EDMAK module: built on Jan 22 2014 at 14:52:02
[  4.010000]  Reference Linux version 2.6.32
[  4.030000]  File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[  4.700000] usb 1-1.1: new high speed USB device using musb_hdrc and address 3
[  4.830000] usb 1-1.1: configuration #1 chosen from 1 choice
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
sulogin: no password entry for root
umount: can't umount /mnt/usb: No such file or directory
login[491]: root login on 'ttyS0'
rmdir: '/mnt/usb': No such file or directory
#Process /etc/profile...
root@Dji-Pro:~#
USBClient version 1.0.23
ReadSize = 2048 Timeout = 90
init  libusb successed!!!
!!!!!!!!!!!!!!!!!!!!!!! open 68013 succeed  VENDOR_ID = 0x0547
Claiming libusb_claim_interface 68013 successed
usbmuxd_subscribe OK OK
watchdog timeout:5
latency1:33332
latency2:33000
latency3:30000
displaybuffnum1:4
displaybuffnum2:9
start decode stream from 68013
decode init ok, main thread exit
Osd_Init_Font succeed
[  9.660000] pinmux1:0x00185555
[  9.660000] pinmux4:0x1155fdff
[  9.720000] pinmux1:0x00185555
[  9.720000] pinmux4:0x1155fdff
[  9.830000] pinmux1:0x00185555
[  9.830000] pinmux4:0x1155fdff
[  9.890000] pinmux1:0x00185555
[  9.890000] pinmux4:0x1155fdff
[  9.950000] pinmux1:0x00185555
[  9.950000] pinmux4:0x1155fdff
[  11.980000] PCLK = 0 -> 0
[  11.980000] HTotal = 0 -> 1650
[  11.980000] VTotal = 0 -> 750
[  11.990000] ScanMode = I -> P
[  12.000000] PCLK = 0,(1650x750) PROGRESS CHANGE MODE
[  12.000000] VIC = 4
root@Dji-Pro:~#
root@Dji-Pro:~#
it seems that now the lightbridge Linux is returned to life.
Fantastic!, You are at a step from the solution... I guess that you are test your Lightbridge? Check with assistant if the firmware is visible, now...
I think there is still some problem.
Look this part of the log:
Code:
it seems like the kernel is not where it is expected.
In a log received from andrew (from a working device) I've seen that the kernel is found at 0x4a0000, not at 0x900000.
but at the end, the entry point is Always 0x80008000, like in andrew received log.
this is the log received from andrew
Code:
Created: 2014-11-27 10:20:54 UTC
Data Size: 4032928 Bytes = 3.8 MiB
anyway connecting it to the assistant, now it finds all the 3 components firmware version. I think that now it works. there is no reason to think different.
Just i wish to understand what happened about the kernel error.
moreover before to flash i erased the memory, so I don't understand why isn't it everything erased. May be that kernel is in another memory zone that you can't erase with the serial flasher tool or may be that the u-boot contains also the kernel? I don't know but I'm happy about the actual result.
Yes, in you log you have the error, but It seems load the kernel from other position.
Now you must try the unit. If work, who care where is loaded the kernel? ;)
Beside, should be a good idea discover WHY the kernel is erased fron fault units. This problem happen a lot. I used my unit only one time, and it is two time that it return in assistance. Please let me know, because if my unit come back fault, I know what I must do.
A (maybe idiot) idea: as you can see the components in assistant, try to update -no matter if the version is the same -, and see what hapen with kernel.
A good idea will be also "grab" the update firmware file in some way.
Also, maybe that environment setting is different (i see some error in your log about this). Can the 0x800 bytes contain environment settings?
