Jello after crash... next possible steps?
Hello,
I was hoping you guys could give me some insight, since there has been so much useful info on these forums. After a small crash I am getting a bit of intermittent jello and shaking from the gimbal in video.
# Foam has been removed.
# Everything has been calibrated. (imu, gimbal, and compass)
# New and balanced blades.
# Took the gimbal apart and both of the halfmoon rods are lined up correctly.
I'll try to post a video. It seems to happen when I change directions, when I change the camera angle, , during gusts of wind, and every other second while panning or going too fast.
Just wondering what could be my next steps?
Thanks guys!
Hello,
Thanks guys!
You only have 2 of the plastic pins in through the gimbal dampers right?
I have seen some put all 4 of those pins in (only supposed to use 2) and it has caused an issue.
Did you check the grub screw at the top of the gimbal yaw arm? It is a very small allen (hex) screw that tightens against the yaw motor shaft.
Sent from my SM-N910V using Tapatalk
shimuafeni fredrik
