Is this sd card any good ?
Hi, after searching around , it seems like I need a card with Uhs-1 and something called U3. I found this Kingston action card, 32GB, UHS-1 and U3. Will this be good for 100mb/s 4K 60fps on the P4P? This is a Norwegian store but , you can see the specs on the title I think .
Kingston microSD Kort 32GB - Micro SD
That one is a step below the current top-line cards. It is Class 10/U3, but it's SDHC vs. SDXC and 45MB/s write speed. I would go with a Class 10/U3/SDXC which should be closer to 90MB/s write speed.
It has 95MB/S write speed , and The difference between SDXC and SDHC is only how many gb the card actually is .
You might be correct on the SDHC/SDXC, however packaging on that card clearly states 90MB/s read, but 45MB/s write.
That one looks good. The SD card ratings/classifications are confusing to say the least.
robvalduga
