Is this normal (rth question)?
My p4 is at 84 feet height altitude, my rth is set at 50 meters (164 ft). My drone is not facing the sun. Upon engaging the rth, my p4 ascended to the maximum height of 394 feet and just hovered. I waited a few seconds but it seemed like it will not come home. I wouldn’t have known if I waited longer if it will actually come back if I hadn’t cancelled rth and just flew her back though. Gladly, she’s in line of sight. I will do my best to upload the log as I’m so ignorant on how to figure that out. Tried before my previous post but failed. I’m sure that if that happened while she far away, I wouldn’t see her again.
Sounds like a VPS issue to me. The logs will confirm that. Do you have a gimbal guard or anything blocking the downward sensors?
Go to DJI Flight Log Viewer | Phantom Help
That will give you a detailed report of the flight.
Reactions: Izzy1970
Such situations are quite often here. Much to often. I thing that DJI should look into the issue.
Thanks for the advices. I was able to correct and fix the problems by downgrading from the latest firmware.
It's extremely unlikely that your firmware made any difference at all.
It certainly did not cause your drone to lose its ability to rth.
Since you never identified the actual cause of your issue, it seems that there really was no issue in the first place.
Operator misunderstanding is the most likely explanation.
