iPad running hot
Mini 2 ambient temp specs state 95 degrees fahrenheit as the max. That's not real high if you ask me. I'm looking at getting a USB fan to see if the micro USB port on the controller will power it and if it makes a difference. If you ask me this is a business opportunity for someone if that port outputs power. You could probably print a bracket that houses and powers 2 fans and attaches to the DJi tablet holder.
I literally received my new Inspire today in KC, MO where it is in the 90's today. I also purchased an IPAD Air for a monitor. I was flying for no more than 10 min and it shut down due to the temp. Has anyone that had problems with iPads shutting down from overheating purchased a hoodie and had that mitigate the overheating issue completely? I would be very interested in your perspective.
Cheers,
Brad
I've had the iPhone go into overheat mode and it was only 95 degrees out.. however, it was also direct sunlight... I need to get a shade...
src72
