Image transmission problems
I'm having problems with image transmission on my nvidia shield k1 tablet with the latest dji go 4 app and also does the same thing with the litchi app as well. Here are some images of the current firmware.
and here's a short video of what's going on as well
and another picture
it wouldn't let me post a video so here's another picture
and another
and another picture
and another
Have you got another USB cord to try
and another picture
and another
I'm using same app version but on Samsung tablet,,had issues like this ..changed my USB cord which worked and also got faster reading SD card now using 64gb with 90mps ,,also my camera on 1080 30 fps
I will try a new cord and if that doesn't work then I will try a different SD card and will post my results
I changed cords and tried 2 different brands that were new in the box and then tried changing SD card and still getting the same results.
I believe I have pinpointed the problem. I installed an hdmi output module on my transmitter and as far as I can remember it's been giving me problems ever since around that time. I have another factory phantom 4 remote with the same firmware on it so I paired it to my phantom 4 and it fixed the problem so I paired my original remote back to the drone and changed the dji hdmi output module out with the original and it is fine. I was wondering has anyone else had any issues and if there module had a copper color type material inside there module. The reason I asked is because the videos I've seen on YouTube didn't have that inside of the module.
Try downgrading the controller firmware to 1.6, there are known issues with 1.8. I don't have the hdmi unit but was getting the same issue, downgraded to 1.6 and no more issue. Apparently with the hdmi it can make things worse on 1.8
Downgrading to 1.6 didn't improve performance for me.
Many have reported having installation problems with the HDMI module on the P4. Everything would work before screwing down the cover but would stop working once screwed down.
robvalduga
