justsomeguy said:baja5b-ss said:OK then Tony
In that vid is the vision crap.
End of
Mostly confused and incoherent to the very end.
At least you're consistent!
Say no more then bob
Sent from a GS4 using tapacrap
End of
travelerX said:Thanks for all replies
I went for some research and I got my new list that i want to buy:
DJI Phantom ver 1.1.1 = $500
Brushless Gimbal: $190
FPV: $270
Battery Pack: $25
GoPro3: 300
all together = $1285.
Apprently I'm thinking Brushless Gimbal should be better than the Vision. And furthermore the FPV range is gonna make the huge difference with the Phantom Vision. What do you guys think? Or should i wait for the Vision without it's own camera?
travelerX said:Thanks for all replies.
What i'm really concered is the Gimbal. I don't have the budget to get the DJI's Zenmuse gimbal which is $699. I only have the budget for Brushless Gimball or Airly Motor Gimbal.
Does anyone here have own one of the gimbal for DJI phantom and what's your review? Thanks!
Gizmo3000 said:travelerX said:Thanks for all replies.
Save up for a Tarot, you won't regret it.
justsomeguy said:miskatonic said:The only problem is that the Tarot is heavy and cuts flight times by 2/3. If you fly the Phantom and want a gimbal you will need to get larger props and then set up dual batteries for any decent amount of flight time.
This is crap advice.
Yes, adding 200 grams (tarot weight) does reduce flight times. However, the Tarot is lighter than many other gimbal solutions.
Claiming that you need larger props and dual batteries is idiotic but considering this tool's other posts it's to be expected.
I have an older Phantom with a Tarot and GP3 and get 6+ minutes of flight time with a Hyperion 2500mAh battery. You do not need a dual battery setup to get decent flight times.
travelerX said:what about the mount? does tarot gimbal come together with a mount for dji phantom? :shock:
