I lost my drone (P3 standard) tonight
OK, updated this post since yesterday with more data. I sincerely appreciate the help understanding where I went wrong. This is a good and supportive community. -Dan (updated post from 11/26 -- now 11/27 6:25pm pacific)
Hello folks-
Sad day for me. I live in a natural oak forest in Oregon. I've been flying for about 2 weeks in the DJI go app. All fine and very much enjoyed it. Tried my first couple of missions in litchi. Went fine. Thought I knew what I was doing. Did a mission hub for a 7 minute mission around my home and the drone lost signal and never came back.
So for the practical stuff:
- Is there any way to determine my drone's last position so I might be able to collect it?
In case curious: my mission had 9 waypoints all at 400'. My idea was to avoid hitting any obstacles of unknown height-- there are definitely trees nearby at 250'. My home has a large enough open area for take-off and landing. The mission was a loop ending right above where I started.
My theory of where I went wrong (just a guess). First my mission had do-nothing (must be default because I didn't assign it) at end of mission. This likely not a problem on its own because mission end was over my home location. I had a good home point and good GPS 11+ satelites at launch. My controller said disconnected after a minute or so of 7 minute flight (expected). My thought is I must of accidentally tapped a up/down/right/left stick near the time the drone lost signal-- causing it to hover (don't know). Since RTH wasn't selected (error on my part) in the mission, it likely hovered until emergency landling.
I don't really know what happened. I normally do lose video and later controller signal in my home area even in .5 mile area because of the tree canopy and terrain. Litchi shows a position for my drone. i tried to hike there tonight- very rough mountain terrain. Didn't make it.
So thoughts:
- Is it likely last position Litchi had is accurate given that it lost signal? i.e. If I really hike/climb to that location do I have any reason to believe it accurate? My concern is that this may be last position it had signal and not real location.
- In general is here any methods to find? My mission had 9 waypoints forming a circle with the last point where I started (also the H - home position.) I thought when battery got low RTH would happen but it did not.
Anyway, thoughts/advice welcome.
-Dan
PS: I'm running latest Litchi bought for black friday sale this weekend. Drone running one back firmware from 1.9. I had been alerted to 1.9 but was waiting a bit to see how people like.
And also FYI- I flew about 4pm today (11/26). It was daylight (mostly) when the craft was lost.
Flight Log: DJI Flight Log Viewer - PhantomHelp.com
Here's a link to the mission: Mission Hub - Litchi
Sorry to hear that. If you have a flight log available to post, many folks here are good at analyzing them.
Of course it the last position that the app got from the drone - right before you lost signal.
After losing signal, it's not going to know where the drone ended up.
Go to: Go to DJI Flight Log Viewer
... and follow the directions to get your Litchi flight record.
Upload it to that site and post a link here.
Also if you can post a screenshot of the Litchi mission planning and a location people can find in Google Earth, perhaps someone might be able to work out what happened.
Sorry to here that buddy. Any chance you could have accidentally set another way point as you tapped the screen? It could be so many scenarios for it not to come back. Thankfully your mission is in a loop so depending how much area it covered you should come across it. Don’t give up tho. My P3A got lost for 24 hours and these guys helped get it back. When you went tracking to find it, did you bring the controller with you to try and pick up signal?
What was the RTH alt at? And also in addition to uploading to the viewer upload your litchi mission so we can look at it.
First point and this is neither here nor there really, but there is no RTH selection in a Litchi mission. End of mission is either, land or hover, that's it. There is really no way to know why the mission did not complete as programmed without taking a look at the flight logs as @Meta4 mentioned above. At the very least, you would be able to follow the flight profile to the last known location. You would also need to fully review your mission profile for any errors. Sorry for the loss.
RTH issue might be involved if the mission was interrupted or toggled out of F mode. The altitude set would then be relevant. Otherwise either a mis-tapped "Extra way point" or a "end of mission setting" would be in play.
Reactions: Pharm
A couple of things come to mind:
1) Battery upon take off
2) Speed settings for your mission
3) Wind speed at 400 feet
As others have suggested, posting your flight log and even a link to your mission may reveal additional clues.
At 400 feet it most likely did not encounter any obstacles, but could have had some difficulty if wind speeds were high preventing the AC from completing the mission before battery rn out, in which case it would auto-land.
I can think of several possible scenarios but until the logs are posted, it’s all guesswork.
So near to the hospital there is a slight chance the signals from the hospital may have interferes with the compass sending it into compass error and ATTI mode. However I have no idea if the mission will continue or RTH when compass error is gone.
Hello folks-
In case curious: my mission had about 7 waypoints all at 400'. My idea was to avoid hitting any obstacles of unknown height-- there are definitely trees nearby at 250'. My home has a large enough open area for take-off and landing. The mission was a loop ending right above where I started....
You most likely hit a tree. I saw a post similiar to this a couple of weeks ago.
Even if you set a rth of 400 feet to avoid obstacles in your flight path, a tree that is 200 feet tall will bring down your Phantom if the ground elevation of the tree's location is 300 feet higher than your launch elevation.
Sorry for your loss. Hopefully you can find it.
Review your flight path and see if you can find the first likely area where the ground elevation + tree and your mission altitude conflict.
Good luck with your search
Reactions: Oso and LarBear360
My P3 pro lost signal by the hospital. I was **** near 30k feet out. The blue line is the path it was rth... second pic was the last connection I had with the aircraft. Haven’t seen it since, despite multiple searches.
Have you looked at the flight data to see what story it tells?
There's a good chance it will explain the mystery and possibly point to a likely search area.
ps .. at that height, the hospital would have had no effect on your flight.
I updated my original post from yesterday with requested data. The mission was a loop-- but my mission final action was set incorrectly to "None" -- I'd of preferred RTH. If the loop had completed the final waypoint was very close to starting point.
Definitely didn't toggle out of F mode. Had read manuals carefully pre-flight.
-Dan
Yes, my wife and I tried over tough terrain to hike to signal lost position. All through brambles and whatnot (blackberrys, poisen oak and the like). We hiked for about 1.5 hours with controller in hand trying to get my blue dot (controller) to overlay last position. Couldn't make it to that exact spot due to elevation gain. I'm pretty familiar with this area and -- of course since I lost the drone can and am sometimes wrong-- but I suspect 400' was enough altitude to avoid trees in the area. The highest point I've witnessed is about 250'-- but it's fair to say the land around here varies in elevation and relative tree height could of got me.
With regard to touching screen-- nope. I will admit I could of gently tapped a stick. But once it started its mission (I hit play and watched it go off) I just stood as still as possible. I did not touch screen (and I did review mission after load before hitting play). Right about the time it flew out of range "disconnected" i may of touched a stick. After 7 minutes passed (and it should be back), I manually invoked RTH with S2 flick. I then got it my truck and drove the path to see if I could get signal. Window down, controller held out window beeping. At a couple of intervals tried RTH again before my ~27 minutes of battery died. Went home for the last few minutes and waited in driveway to see if it would return. -Dan
You were flying a Standard, so losing signal at the distance you did is not unexpected.
We only have very limited information but looking at the route you set, I see one obvious problem.
Your home point is at about 940 feet altitude and there is a point on the route where Google Earth shows an elevation of 1346 ft (and there would be tree height to add to this).
400 ft would not be sufficient to clear this high point.
If everything went without a problem, when your Phantom got to this high ground, it will have crashed.
Here's a rough location for your search area.
You can refine it by zooming in on your Litchi flight plan to see the track it would have taken here.
Search from the south as the drone probably hit a tree before it got to the higherst land.
It's a little less dense than some of the other parts of the route.
Good luck with the search
Here's your search area.
Agreed. The 400 ft relative altitude was not adequate for the terrain:
