I crashed my Phantom 3 DJI Advanced. Help?
So, I crashed it into my garage door because I wasn't being smart or wise. Anyway, it seems to run fine. What I was wondering is there anyway to run diagnostics on the Phantom to look for errors? I was not paying too much attention to how it performed until I crashed it, but it does seem like it doesn't hover in the same spot so well. At least indoors. I haven't really taken it far ever since I crashed it. Might the hovering issue be something to do with the props? I ordered the new Carbon Fiber ones along with a new set of guards. They will be here tomorrow.
A few thoughts:
- If your props are damaged in any way, that could have an impact on the stability. Be careful flying with damaged props -- they could have damaged hubs too.
- Try new props and see if it makes a difference. I don't recommend using 3rd party props if that's what you mean by carbon fiber props. If they are DJI carbon fiber reinforced props, then they are okay to use.
- Turn off VPS. That can cause an unstable hover depending on the surface you're flying over.
- Be careful flying indoors. It's easy to crash inside -- unless you're referring to flying in a gymnasium.
Thank you. The props are just slightly damaged though, but that still could be impacting my stability on hovering? I'm just afraid that I hurt it somewhere other than the props.
You'll have a better idea after you install your new props, disable VPS, and fly outdoors. Until then, anything is suspect.
Inches.. feet?
That doesn't sound too bad. Can you post a video?
replace the props,
they are spinning at high rpm and completely control flight,
unbalanced props equals flaky flights
good luck and have fun flying!
DonT
