Advanced I crashed my Phantom 3 DJI Advanced. Help?
Discussion in 'Phantom 3 Help' started by Timothy James, Dec 14, 2015.
  1. Timothy James
    So, I crashed it into my garage door because I wasn't being smart or wise. Anyway, it seems to run fine. What I was wondering is there anyway to run diagnostics on the Phantom to look for errors? I was not paying too much attention to how it performed until I crashed it, but it does seem like it doesn't hover in the same spot so well. At least indoors. I haven't really taken it far ever since I crashed it. Might the hovering issue be something to do with the props? I ordered the new Carbon Fiber ones along with a new set of guards. They will be here tomorrow.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Nope.
    Try doing an IMU calibration.
  3. Timothy James
    I did. Is it because I'm flying too low? Why it is not hovering smoothly, plus the damaged blades?
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Are you saying you're flying with damaged props? If so, that's not a wise idea.
  5. Timothy James
    I'm saying I'm hovering with damaged props. They're not that bad, they're just a little scarped. I am not flying really.
  6. Skywalker
    Amelia Island, FL
    Then don't be surprised when you crash "just a little"...
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    A few thoughts:
    - If your props are damaged in any way, that could have an impact on the stability. Be careful flying with damaged props -- they could have damaged hubs too.
    - Try new props and see if it makes a difference. I don't recommend using 3rd party props if that's what you mean by carbon fiber props. If they are DJI carbon fiber reinforced props, then they are okay to use.
    - Turn off VPS. That can cause an unstable hover depending on the surface you're flying over.
    - Be careful flying indoors. It's easy to crash inside -- unless you're referring to flying in a gymnasium.
  8. Timothy James
    Yes that I do mean the DJI Carbon Fiber ones. It just doesn't hover the best. How do I turn off VPS?
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
  10. Timothy James
    Thank you. The props are just slightly damaged though, but that still could be impacting my stability on hovering? I'm just afraid that I hurt it somewhere other than the props.
  11. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You'll have a better idea after you install your new props, disable VPS, and fly outdoors. Until then, anything is suspect.
  12. Timothy James
    It still is drifting some. I'm not really sure if it's normal to drift or not.
  13. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Inches.. feet?
  14. Timothy James
    I'd say no more than 1 foot.
  15. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That doesn't sound too bad. Can you post a video?
  16. Timothy James
    Yeah I'll try to get one up soon. I have a bad upload speed, but I'll do my best.
  17. kirk2579
    Girard. ohio
    replace the props,
    they are spinning at high rpm and completely control flight,
    unbalanced props equals flaky flights
    good luck and have fun flying!
  18. Jumping
    Sargent, Texas
    Are you flying over a concrete floor? The steel reinforcing bars definitely influence the compass negatively. See Post #7 above.
  19. Diehard
    Arcadia
    That's FUNNY!!
  20. TC Malker
    Cool! DJI put back the “format data recorder“ option. Or did they? What version GO app?
Similar Threads - crashed Phantom DJI Forum Date
Crashed my Phantom while wearing my DJI GoggleI DJI Goggles Jun 26, 2017
Crashed DJI Phantom 3 Prof. Pro/Adv Discussion Feb 4, 2016
WANTED - crashed DJI Phantom 2/Vision/Vision+ Classifieds Dec 10, 2014
DJI Phantom Vision crashed - camera is loose Phantom 2 Vision Help Jun 24, 2014
Crashed my phantom4 for unknown reason Phantom 4 Pro Help Monday at 2:31 PM
