- Joined
- Dec 12, 2015
- Messages
- 201
- Reaction score
- 72
- Age
- 55
Impilot51, 2.5 would be the GO app version, not firmware. The latest firmware is 1.6, are you talking about the GO app or the firmware?
Your description sounds a lot like some flights I've looked at lately where propulsion was lost in one motor/prop. See Professional - Need Help With P3A Crash | DJI Phantom Forum It may look like a compass issue but, the P3 actually is spinning. If you want either I, @Luap, or @TheRealNick to look at please retrieve the .DAT and DropBox so one of us can take a look.Guys I have made hundreds of flights with my P3 Pro and never had an issue. I had flown on christmas but did not do the latest updated that was pushed on 12/22 until last week. I flew that morning after the update and everything was fine. Next flight that afternoon I flew for 10+ minutes and had 45% battery left on my descent to end my flight i was maybe 100 feet altitude and all the sudden it starts going crazy jerking in all four directions like it was unstable coming down. I tried everything hitting the sticks back up, left, right...etc and it would not stop coming down jerking in all four directions like it was very choppy. So I immediately start running for it to try to catch it and it lands on the top of it flipped upside down and I grab the leg and then it is still stuck in full throttle trying to take off props spinning as fast they could. I was doing everything I could to try to hold the phantom from flying off again. I was not holding teh controller I had set it on the ground so nothing was telling it to try to take off again. I ended up having my son come over and try to push the sticks to shut it off and it would not respond to that. I then tried to reach up with one hand as the props are spinning full speed to try to shut the battery off and it would not respond to that. I ended up having to pull the battery while risking getting cut with the props, it was stuck in full throttle up at this point.
I have never had a crash or any types of issues, I know there are other thread on here but where in the world do I try to begin on what type of issue this was and what I can do to resolve it?
Thanks so much!
Thanks for a response, I cant seem to get my phantom to mount on a mac to get the .dat file does anyone have any tips on that? I have tried everything.
Not compass related.It appears your craft lost it's compass calibration somehow mid flight at 10:42.
???I know I shouldn't push 100% down on landing but ya know.
It's not clear here ... did you use CSC for emergency stop and did it fail to work? ... or did you try other things and not use CSC?.... it lands on the top of it flipped upside down and I grab the leg and then it is still stuck in full throttle trying to take off props spinning as fast they could. I was doing everything I could to try to hold the phantom from flying off again. I was not holding the controller I had set it on the ground so nothing was telling it to try to take off again. I ended up having my son come over and try to push the sticks to shut it off and it would not respond to that. I then tried to reach up with one hand as the props are spinning full speed to try to shut the battery off and it would not respond to that. I ended up having to pull the battery while risking getting cut with the props, it was stuck in full throttle up at this point.
Other machines might not have the offset motors of the P3 which prevent VRS on full speed descent.like you were descending with full down for a bit before it started spinning. I am not sure if that could have caused it. I know a lot of people say you can do full down, but from flying other RC helis they seem to act werd when you do this so I have formed a habit of not doing it.
The compass had nothing to do with the problem.If the compass direction in the file matches the actual orientation of the aircraft then it is probably not a compass issue, but with the .dat file we could rule it out...
It's 100% safe to descend at full speed in a P3 without prop guards.
The only time compass data looks wrong is when it has already crashed.
It's a symptom, not the cause.
Earlier models this is true. P3 is not prone to this. Motor angle offset has fixed this in the P3.I do know that descending with the throttle all the way down can cause a quad to crash.
Vortex ring state - Wikipedia, the free encyclopedia
Quadcopter Flight School: Vortex Ring State (The Wobble of Death)
Sent from my iPod touch using PhantomPilots mobile app
Ok my bad.The p3 is not very susceptible to Vortex Ring State. No saying it wont get a small amount of wobble but very little. I also as a habit do not like to descend straight down but my p3 handles it just fine. Yesterday I flew in very windy and cold conditions at got a slight bit of wobble doing a straight down descent where there was not much room for landing and it handled it just fine correcting the wobble after about 2 seconds. Gimble corrected movement so its not even visible in the video.
My guess is that DJI has programmed the IMU unit to detect this condition and it applies diferential thrust to recover. Having flown quads for some time it is rather difficult to recover, but so far I have not been able to get my P3 to even think about getting into this situation. It could also be that the P3 is coded to not allow for an overly rapid decent.
My bad.Earlier models this is true. P3 is not prone to this. Motor angle offset has fixed this in the P3.
