How to tell what Firmware is on RX
I know the tablet will tell you if its not up to date. But if you wanted to check connect it directly to the quad gimble turn the quad on first then the remote, a log file will start and tell you if it upgraded, needs an upgrade or if your on a current version that has already been installed. To see that turn it all off and pull the memory card out of the quad and into the comp to check it.
Reactions: JoeyJoe
The latest firmware will need to be on your memory card too. Otherwise, the TXT log file will not be generated.
