How to separate Gimbal Arm from Main Gimbal Board
Cupertino, California
Hello, I am trying to replace the top gimbal board for the gimbal. But how do I separate the bottom board from the arm? There seems to be a press-fitted black screw securing it in place. Any ideas? Thanks.
It's not pressed in....it's a small grub screw. You need either a small hex key or a torx screwdriver to undo it (check the head to see which you need ...I think it's a 1.5mm hex)). Just loosen the screw, and the arm slides off.
robvalduga
