Hello, I am trying to replace the top gimbal board for the gimbal. But how do I separate the bottom board from the arm? There seems to be a press-fitted black screw securing it in place. Any ideas? Thanks.
It's not pressed in....it's a small grub screw. You need either a small hex key or a torx screwdriver to undo it (check the head to see which you need ...I think it's a 1.5mm hex)). Just loosen the screw, and the arm slides off.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
