I haven't used the Argtek, but generally, the long antenna should be vertical with the face facing the Phantom, the 2 panels should be pointing the faces at the drone. Don't be afraid to adjust them in flight - just always be aware where the Phantom is relative to you, and keep an eye on the signal strength meters
Got it, thanks!Yes, although I would tip the long antenna back parallel with the panels, the face of it should be pointing to the phantom, not the tip
