How to orbit?
So I'm working on orbiting around an object, keeping the camera trained on that object, but I'm having problems with it because I usually just end up going way faster then I need to be, as any adjustment in roll needs to be countered with an adjustment in yaw, so I end up speeding up. Any pointers? I'll try to put up some video later.
Sent from my iPod touch using PhantomPilots mobile app
Use the intelligent flight mode "around a point" and follow the directions on the prompt. Center position on toggle switch
Why not just use the POI feature?
I'm using a iPad without gps so I can't use any of those. No dynamic home point. I also want to know how, just because. [emoji16]
You don't need GPS on your iPad in order to use the POI feature.
You want to do it manually, I get that... even though the intelligent flight modes can do the hard work for you... OK, so obviously, it takes the proper combination of stick inputs for yaw and forward/sideward pitch/roll to establish the "circle" around the centerpoint... there's no magic other than keep practicing and find you're balance point with constant fine tuning of flight controls.
I asked a similar question early last week, msinger and DAP-UAV gave me the awesome advice of turning the gain levels way down. "Way down" is pretty subjective, so I will just say cut them in half to start with and see if you have better results. I have been toying around with it both on the simulator and in the air and I have to tell you that it's a lot easier now for me to get shots that are smoother with way better stick to movement results I feel like.
Ok just did that. My bad.
Nwbailey
