P3 Firmware HOW TO: Install Phantom 3 firmware
You are off base. OP already confirmed that the small correction that I suggested was correct: http://www.phantompilots.com/thread...3-firmware-if-using-dji-go.50065/#post-478754
I pointed him on your mistake too,
Read this again and tell me please what yours COMPUTER has to do here:
30) Turn off your remote controller.
31) Insert your memory card into a memory card reader and plug the memory card reader into the USB port on the back of your remote controller.
Note: If you do not have a memory card reader, then do the following:
  • Insert the memory card into the camera memory card slot on your Phantom.
  • Connect the DJI USB cable from your camera to your remote controller.
  • Remove the props from your Phantom.
  • Power on your Phantom. To do so, press and release the battery button quickly -- and, then immediately press and hold it in for 2 seconds.
32) Turn the remote controller on and wait for the update to begin. It can take up to 60 seconds for the update process to start.
33) The remote controller status light will be solid blue while the firmware is installing. The remote controller status light will be solid green when the update has successfully completed.
Note: Do not power off and/or touch any buttons on your remote controller while the firmware is being installed. If the remote controller status light does not turn solid green, then go back to step#30 and repeat the installation process.
So now! Are you agree that yours correction was rubbish????
3pa4ok: Let me see if I can assist you in understanding this. You are in fact arguing in support of the change that I proposed to the OP, which the OP has agreed to be correct.
  • The change I proposed to the OP on post #9 (HERE) was for step 31 (for users updating the remote controller firmware, and using the P3 gimbal as their card reader).
  • Here is the original language from the OP: "Connect the DJU USB cable from the camera to your computer"
  • Here is the language I suggested to the OP, which he agreed is correct, and which he subsequently incorporated into his original post: "Connect the DJU USB cable from the camera to your transmitter"
If you bring this up again, we are left with no other option than to conclude you are a troll, intentionally trying to confuse everyone. If there is any doubt, please ask the OP instead of putting words in their mouth.
3pa4ok, I believe the current instructions above are correct as-is. If not, please let me know. Otherwise, let's try to stay on topic here so we don't trash this useful thread :)
Yes, and there is my great apologies if we are on the same side.Sorry man and everybody who got confused because of And bot there is clear now we were talking about the same thing. I got it wrong simply because the English is my 3d language but this is main personal problem and no one should suffer becouse of this.Did not want to be impolite ,one more time sorry for the mess.
Reactions: UAV-Video
All good 3pa4ok
Reactions: chrislongley
A friend of mine just received his brand new P3. He made a mistake installing the older
Phantom 3 Professional Firmware v1.2.6. He flew the P3 twice but now the app shows the "upgrade your aircraft" . I am familiar with phantoms so I know how to update the
Phantom 3 Professional Firmware v1.3.20. Format sd (FAT32-exFAT) /drag .bin file/insert sd into P3/turn it on/ then nothing happened. He open the TXT file and says identical firmware blablabla ABORT. He have tried it 3 times and it does nothing.
Any idea ????
Tell your friend to follow the instructions above exactly. It sounds like he missed a step somewhere.
Filling instructions to a T will not upgrade and tried to downgrade, nothing. The lights just keep flashing with no beeps at all
It sounds like the firmware is not in the root of your memory card.
could really use some help here, I;m trying to upgrade and after I insert the SD card (yes with file on it) the A/C powers up then I get D-D and a solid green led....
What am I doing wrong....this time?
George F, the steps above are very detailed and they work flawlessly if followed exactly. If they do not work, you did something wrong or your Phantom is defective and you need to send it into DJI to be repaired. The latter is not likely.
Did you format your memory card first? Did you unzip the firmware to the root of your memory card?
Can anyone tell me why it isn't generating a txt file? All seems to be fine, the green/red flashing little light changed to solid green etc but it doesn't put a text file on the card.
AlmostTan, that seems to be the case. See more here:
Updating firmware for REMOTE CONTROLLER | DJI Phantom Forum
I got all updated and can't seem to find all the new features. when I go to overall status it shows I have done all the latest updates, so why can't I use way point or home ,course lock. etc????? the app was also updated but doesn't show me these options its like nothing ever changed...
I am using iPad
My Transmitter will not take any software update at all. The camera is on the latest version and the remote on the last version.
I have tried via the usb and the cabled options and it sits parked on a red light and after a couple of minutes just gives a single beep for about one minute then stops .... Any thoughts ??
Than ks
Follow the steps below to install the latest firmware on your Phantom 3, remote controller, and Phantom batteries. Ensure you follow the steps from top-to-bottom. Carefully read each step and ensure you perform them exactly as written.
Do some research to make sure the firmware update is stable.
1) Before installing a new firmware update, check this forum and the DJI forum to see if others are having any trouble after installing the update. If a few days have passed and nothing major has been reported, then it's a usually a good sign that the update is safe to install. Some people enjoy installing the latest and greatest right away, so let those people test the updates if you want to play it safe.
Note: After upgrading your firmware, it's possible to downgrade your firmware if the update does not work as expected. You can downgrade back to the previous version -- or, even as far back as version 1.1.9.
Download the firmware.
2) Download the latest firmware ZIP file from DJI's download page.
Note: The Phantom Professional, Phantom Advanced, and Phantom Standard use different firmware.
Review the release notes so you understand what was changed and you're aware of any special installation instructions:
Phantom Advanced Release Notes: http://download.dji-innovations.com...n/Phantom_3_Advanced_Release_Note_en_0907.pdf
Phantom Professional Release Notes: http://download.dji-innovations.com...antom_3_Professional_Release_Note_en_0907.pdf
Prepare your memory card.
3) Delete all files from your memory card or format it.
4)
Open the firmware ZIP file downloaded in step #2 above, extract the BIN file, and copy it to the root level of your memory card.
Install the firmware on your Phantom.
5)
Ensure your Phantom battery is at least 50% charged. This means you should see at least 2 lights illuminate when pressing the power button. If needed, stop here and charge your battery until it is at least 50% charged.
6) Make sure both your Phantom and remote controller are turned off.
7)
Remove the props & gimbal lock from your Phantom.
8) Insert the memory card into the memory card slot on the camera.
9)
Insert the Phantom battery into your Phantom and power it on. To power on the battery, press and release the battery button quickly -- and, then immediately press and hold it in for 2 seconds.
10)
Watch the camera status light to monitor the installation process. It should do the following:
  • Flash green while your Phantom is starting up.
  • Alternate between red and green while the firmware update is being installed.
  • Turn solid green when the firmware update successfully completes. You will also hear a D-DD beeping sound that repeats.
Note: The lights under the Phantom arms might flash different colors. Your Phantom might beep in different patterns (even a solid tone). The camera might move or spin around. Ignore all of these things and wait for the camera status light to turn solid green (or solid red if the update fails). This process could take up to 20 minutes to complete.​
11) When the camera status light turns solid green, power down your Phantom by turning off the Phantom battery. To power down the battery, press and release the power button quickly -- and, then immediately press and hold it in for 2 seconds.
12) To verify the firmware installed successfully, open the TXT file that was created on your memory card and verify that the last line of the TXT file includes "success".
13) Delete the TXT file from your memory card.
Install the firmware on your remote controller using the DJI GO app.
Note: Some firmware updates do not have to be installed on the remote controller. Read the current firmware release notes for more details.
14) Install the DJI GO app (v1.2.0 or higher) on your mobile device. If you have an Apple device, you should install the DJI GO app from the App Store on your Apple device. If you're using an Android device, you should download the DJI GO app from DJI's download page.
15) Turn on your remote controller. To power on the remote controller, press and release the power button quickly -- and, then immediately press and hold it in for 2 seconds.
16)
Ensure your remote controller has at least 50% battery level (at least two white lights are lit up at the bottom of the remote controller). If needed, stop here and charge your remote controller.
17) Connect your remote controller to your tablet/phone using a USB cable (for Android devices) or Lightning cable (for Apple devices).
18) Turn on your tablet/phone.
19) Verify that your tablet/phone has at least 30 MB of free memory. If it does not, remove some unneeded files and/or uninstall some unneeded apps to free up enough memory.
20) Connect your tablet/phone to the Internet.
21) Start the DJI GO app.
22) Click the "Enter Camera View" button.
23) Click the rectangle status message at the top, center of the DJI GO app. You should see an "Upgrade Required" message to the right of "Overal Status". If you do not see this message, disconnect and reconnect your USB/Lightning cable.
24) Click the "Upgrade Required" message.
Note: If you see the "This RC doesn't support upgrading firmware through App" message, then go to step #30 below and install the firmware using a memory card.
25) Tap download the firmware update package to download and install the firmware. A progress bar will be displayed to allow you to track the installation progress.
26) The remote controller status light will blink blue while the firmware is being installed. The remote controller status light will blink green when the update has successfully completed.
27) When the remote controller status light blinks green, power down your remote controller via the power button. To power down the remote controller, press and release the power button quickly -- and, then immediately press and hold it in for 2 seconds.
Note: If the remote controller status light turns red, then continue on to step #30 below to retry the installation using a memory card.
28) To verify the firmware installed successfully, open the TXT file that was created on your memory card and verify that the last line of the TXT file includes "success".
29) Delete the TXT file from your memory card.
Install the firmware on your remote controller using a memory card.
Note: You can skip this section if you successfully installed the firmware update on your remote controller by following the instructions starting at step #14 above.
Note: Do not power off and/or touch any buttons on your remote controller while the firmware is being installed. If the remote controller status light does not turn solid green, then go back to step #30 and repeat the installation process.
34) To verify the firmware installed successfully, open the TXT file that was created on your memory card and verify that the last line of the TXT file includes "success".
35) Delete the TXT file from your memory card.
Install the firmware on your Phantom batteries.
Note: The firmware was installed on your battery when you installed the firmware on your Phantom in step #3 above. If you only have one battery, then skip to step #46 below. If you have more than one battery, then repeat the following steps for each additional battery.
36) Ensure your Phantom battery is at least 50% charged. This means you should see at least 2 lights illuminate when pressing the battery button. If needed, stop here and charge your battery until it is at least 50% charged.
37) Turn off your Phantom.
38) Remove the props & gimbal lock from your Phantom.
39) Insert the memory card into the memory card slot on the camera.
40) Insert the Phantom battery into your Phantom and power it on. To power on the battery, press and release the power button quickly -- and, then immediately press and hold it in for 2 seconds.
41) The upgrade process will begin automatically after your Phantom is powered on. Watch the camera status light to monitor the installation process. It should do the following:
42) Power down your Phantom by turning off the Phantom battery. To power down the battery, press and release the power button quickly -- and, then immediately press and hold it in for 2 seconds.
43) To verify the firmware installed successfully, open the TXT file that was created on your memory card and verify that the last line of the TXT file includes "success".
44) Delete the TXT file from your memory card.
45) If you have additional batteries, then go back to step #36 above and repeat these steps with the next battery.
Keep or delete the firmware BIN file.
46) At this point, you can delete the BIN file from your memory card -OR- keep it on your memory card. DJI recommends keeping the BIN file on your memory card in case you need to install it on new batteries in the future.
Check and/or restore all settings in the DJI GO app.
47) Open the DJI GO app and verify that all of your previous settings are still set. You'll want to do this while your Phantom is turned on (with the props off) and your remote controller is connected to the DJI GO application via your mobile device. This is important since many of the settings are saved on the Phantom itself.
Recalibrate everything.
48) Do the following calibrations from within the DJI GO application:
- Calibrate the IMU (even if it's not required)
Note: See this video for important IMU calibration tips.
- Calibrate the gimbal
- Calibrate the remote controller (RC)
- Calibrate the compass
Mike-- Thanks again for your great posts re the P3!!--They are the best! :):)
